Hello all,
Over a month into Tesla ownership (Model Y long range) and used a 250kw Supercharger at the weekend.
The car was about 15% when plugged in and over the course of a relatively quick spot of food returned to find the car 99% full - amazingly quick (normally set the car to a max change of 80% but when I charged it at home the day before let it go to 100% because of a long road trip - and hadn’t reduced it back down).
When I ended the charge the display in the car suggested a cost of c.£35.
Having downloaded the invoice today the bill is just shy of £50 as it charged me £0.67 per kWh (up from £0.53 a few weeks back).
The invoice also suggests it put 73kwh into the car. Which is 97% of the usable battery? But it should have only put in 85%.
Some thoughts / questions:
(1) Is it normal for the car to not display the correct fee at the time?
(2) Maybe I missed it, but does it tell you the rate per kWh when you plug in? £0.67 is expensive
(3) What is the usable battery? I thought it was 75 - if it is how accurate is either the in car % charge OR the charger log ? One of them seems to be wrong.
