Supercharging - distance from transformer
Discussion in 'Model X: Battery & Charging' started by ToddS, Apr 10, 2017.
  1. ToddS
    ToddS Member
    Jupiter, FL
    I was Supercharging last night after a trip to Disney. It was the Fort Drum SC. Nice 6 or 8 stalls, all pull-ins.
    Since all the stalls were open, I decided to do a little experiment. I started charging at the furthest stall from the transformer and then moved to the one closest. It showed about a 30% improvement in speed moving the the SC closest.
    Thoughts?
    Also, I know the chargers slow down as the batteries get past a certain point. My question is does it matter if it is set on "Daily" vs. "Trip"? In other words, does putting the battery at 100% charge allow the SC to charge quicker for longer (seems that it wouldn't, but just curious of others thoughts)?
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    No, your max charge setting is irrelevant, just the state of charge of the battery.
  3. wycolo
    wycolo Active Member
    WA & WY
    Actually you should use the shortest wiring to the charger racks which are located inside the enclosure.
  4. BerTX
    BerTX Supporting Member
    Texas/Washington
    It's an interesting thought. My guess is that they couldn't possibly use wire that would make more than a 1% or so difference in charge power. There would be too too much heat buildup.
    I have on several occasions experienced a difference in charging speeds between stalls at an empty Supercharger. That's probably what you saw.
    I wonder if there will be much answer from SoCal, where they have no concept of choosing their charging stall? ;)
  5. ThisIsTrue
    ThisIsTrue Re-member
    'Western Slope' Colorado
    Not convinced that distance from the transformers could make a 30% difference. It could be as simple as the first time you plugged in, that it warmed the battery up to a level where it could take the most charge, and then you moved and sure enough, it could take a heavier charge now.
    But I'm not sure -- just a theory!
    • Like x 4
  6. spentan
    spentan Active Member
    SoCal
    This is definitely the more likely situation.
    I've always got the full 120kW from the furthest charging stall when around 7-8% SOC
  7. FlyF4
    FlyF4 Member
    Sparks NV (Giga-Town)
    Good theory. I agree and am sure that distance to the transformer will not make this much difference in charging.
