Most are manual. @tes-s can help.Just curious, how is the badges updated in the new format?
Not that I REALLY want my "Europe Leader" badge back
Badges are a work-in-process and are not being updated currently. We put in the structure for badges and converted old badges, but we have ideas on overhauling the maintenance process including automating some of the badges similar to the way centuries were automated.Just curious, how is the badges updated in the new format?
No rush!Badges are a work-in-process and are not being updated currently. We put in the structure for badges and converted old badges, but we have ideas on overhauling the maintenance process including automating some of the badges similar to the way centuries were automated.
It's on the list....
Unvisited by anyone in this game. It will turn red as soon as someone checks-in on supercharger.life. Any visit on the same day counts as a "first visit" within the context of this game.Green is unvisited by anyone.
Ok, that functionality is odd then. I got to the map by clicking on "Map" on another user's page. Based on that interaction one would assume they would be viewing the map of that user's checkins, which would mean all pins would have to have at least one check in. It seems odd to have to toggle to show that user's checkins when I explicitly navigated there from a user's profile.Green is unvisited by anyone.
All maps on supercharging.life are configured to show unvisited because that is the game's purpose. You can toggle visited on as you indicated or you can visit Tableau for many more views of a competitor's activities.Ok, that functionality is odd then. I got to the map by clicking on "Map" on another user's page. Based on that interaction one would assume they would be viewing the map of that user's checkins, which would mean all pins would have to have at least one check in. It seems odd to have to toggle to show that user's checkins when I explicitly navigated there from a user's profile.
You can use the "recent check-ins" view to see who's been active in the last couple of days.Ok, that functionality is odd then. I got to the map by clicking on "Map" on another user's page. Based on that interaction one would assume they would be viewing the map of that user's checkins, which would mean all pins would have to have at least one check in. It seems odd to have to toggle to show that user's checkins when I explicitly navigated there from a user's profile.
There are 4 map views when you click on "map" for a user from their page. Click on the view you want to switch between the different views (the three you are not viewing will appear in blue indicating they are clickable).Ok, that functionality is odd then. I got to the map by clicking on "Map" on another user's page. Based on that interaction one would assume they would be viewing the map of that user's checkins, which would mean all pins would have to have at least one check in. It seems odd to have to toggle to show that user's checkins when I explicitly navigated there from a user's profile.
Touchscreen is probably blocking your location which the website uses to bring up the list of superchargers near your location, and position the map with your location as the center. Look at the "Using supercharging.life from the car's browser" section of this post and see if that helps. Supercharging.Life databaseI used this feature yesterday while heading up the Peninsula.
First, it worked almost flawlessly. I think the movers and shakers behind this should take a bow (or curtsy.)
Second, I entered my check-ins from the touchscreen. It was not intuitive. I clicked on "check-in." That returned a big zero and scolded me about some sort of geolocation thingy. So, I guessed to go to my map. Again, I was scolded about this geolocation error. However, the pins did show up after I dismissed it. All I had to do was slide the map over until I was in the general vicinity. (I think it centers on Iowa.) Then, I blew up the map to find the specific pin. Then I pressed the pin and the "check-in" screen appeared. However, the first couple of times I did not notice the "Submit" button at the bottom of the comment boxes. (Maybe if the submit button were highlighted in a bold color?)
Small nits, to say the least. Well done and thank you!
Should I do things differently next time?
Ok, thank you!Touchscreen is probably blocking your location which the website uses to bring up the list of superchargers near your location, and position the map with your location as the center. Look at the "Using supercharging.life from the car's browser" section of this post and see if that helps. Supercharging.Life database
Pretty sure you can zoom by "pinching" and move the map by "dragging".Ok, thank you!
I did not notice the tear drop with the little red x. I changed the command to allow geolocation. Now, my map is centered on California. Do the dimensions remain constant, or do they expand and contract? (In other words, I will need to dial in or dial out to select the pin.) Not a problem one way or the other! With chronically slow Supercharging speeds, I need a little extra activity to while away the minutes.....
I won't be on the road any time soon.
We will track this request. There is no harm in a double-check-in. You can always delete the second check-in later. The database allows multiple check-ins to a location for those who want to track all of their Supercharger stops. We are considering several ways to warn you that you've recently checked-in to this location already.It’s awesome. My trips used to be a handwritten list of an apparent loop that I’d figure out at the time of departure. And I’d record my visits in Notes at each stop. Now, I just get I. The car and look at my map to see what’s next. And I copy paste all my visits when I get home.
Is there a reason that multiple check ins at the same site is possible? I’d prefer that I’d be alerted to the fact that I’m trying to check in at an already visited charger. Could save a costly mistake.
This is exactly why supercharging.life is so much better than the old spreadsheet.It’s awesome. My trips used to be a handwritten list of an apparent loop that I’d figure out at the time of departure. And I’d record my visits in Notes at each stop. Now, I just get in the car and look at my map to see what’s next. And I copy paste all my visits when I get home.
Here is an example of a dup checkin.We will track this request. There is no harm in a double-check-in. You can always delete the second check-in later. The database allows multiple check-ins to a location for those who want to track all of their Supercharger stops. We are considering several ways to warn you that you've recently checked-in to this location already.
