Tesla did this for a reason. They know who is charging and for how long. It will make a difference.There is nothing to support the claim this will "actually eliminate that waiting queue".
I'm glad you are not running Tesla.
Fear not, my friend, fear not. The buildout continues. Lots under construction and permitted in the US and worldwide.I'm getting worried about Tesla continuing to build Superchargers at all
Saying all that, however, I still am very firm in my own personal position of, "every car is not for every person" and "it someone bought the car and cant charge mostly at home (or at least at work), then they made a mistake purchasing this car... and I have little to zero sympathy for people who have to constantly supercharge in such a state. OP states "most of my charging can not be done at home". I have no idea how someone could afford a model X and not be able to charge at home, but /shrug. Maybe there is some good reason other than "I want my free unlimited supercharging, and right now its not convenient for me, so tesla needs to do something more to make it convenient for me... otherwise they are failing"?
I don't really see this as a big deal since (1) it only affects a small part of the chargers that are already overcrowded
Exactly. It would be super annoying if there’s a line at a supercharger and some douche (or more than one douche) is charging to 100%.
I say up the idle fee as well so that owners are back in their cars and ready to go ASAP. As others have said in high restate areas it would be bad practice to build large superchargers in New York City or Downtown LA. They really should have large superchargers outside the city to facilitate road trips.
And more level 2 tesla destination in grocery store malls, CVS, Targets, Trader Joe’s, Walmart’s etc...
I only supercharger on road trips so the 80% limit caught me off guard when I discovered it but it makes sense to me. I haven’t supercharged since the first week I got the car in late April. I personally like to charge up to 80 because I don’t like the idea of arriving to my destination with 15% of soc.
Every illustration I can find shows every stall with two connectors. Have you seen this in the wild?
I wonder if a better approach would be to apply a “range charging” surcharge that ~doubles the cost of electricity over 80%.
Might be more effective and equitable than the current approach, although the level of pearl clutching would likely be even higher.
I tend to end up with about the same percentage left (20-30%). Probably depends on how you drive and the weather. 150 miles uses about 40 kWh of energy. The more common 100 miles, uses about 25 kWh of energy. (Assumes nice weather an not too much wind.)
Actually it already does that in a lot of the country. Where I am at it is 23 cents for over 60 KW and 12 cents below. So at 60 KW you are getting 1 kwh every minute, or paying 12 cents per kwh. At 80% you are running about 35 kw or less so you are paying almost 2x, at 90 you run 25kw approaching 3x. At 95 it runs about 6 kwh. So at 95% you are paying almost 10x per kwh than you do at 70% when most charging crosses the 60 mark.
This is all based on long range model 3 150 kwh supercharging as graphed: 150kW Supercharging for Model 3
Note that the short range gets charged even more since the kw drops faster
Agreed but how many people are raised with the value of consideration of others needs. It’s less and less these days in my opinion and more about me me me. Sometimes companies have to push people to make their decision for them.
I think yesterday even with the highway driving I saw my trip usage was significantly below 333 Wh/mi which is unusual in a model X. I still had 36% when I stopped to charge. I've got 82% now and there's a chance I might have enough to not stop to charge on the way home if I don't do much local driving this weekend. That will be a first I think.
You’ve got 12-24 or 36 hours of overnight L1 charging opportunities on a weekend trip. Use it. Even at 3mph that’s 36, 72, or 108 miles added.
when I am on trips, my goal isn't to reduce the time charging to a minimum. It is to minimize my trip time. If I need an hour to take a meal break, then it is actually counter productive to have to stop in the middle of my meal, run out to the car to move it when done charging, then return to the restaurant to finish my meal.
Still, 40 kW in 15 minutes is 160 kW which is much more than any charger I've seen will do. I guess that's the high end of your point and not 15 minutes, still, those numbers all assume perfect charging (not sharing a pair) and a model 3 I suppose. It is also based on always having a convenient charger when you need a charge. My travels take me by Superchargers only on the road and if I don't charge fully, I often don't have enough to reach a Supercharger and either have to drive out of my way or stop at an L2 charger.
It's still an honor system. When you plug in it changes your charge limit to 80%. Just set it back to 100% while charging if you want to stay longer.
Not as of now. May change in the future.I wonder if the charger will still stop at 80 anyways though.
