  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Supercharging speed collection
Not sure if this will catch on or not, but worth a shot. I have been doing a lot of searching on the forum for supercharging speeds of Model S through the years and specifically with software updates. Although this will be anecdotal and there are many factors, I was hoping we could get a thread going where we give simple answers as to which Tesla Model version we have, which software, which MCU, and what the total SOC + current supercharging speed equals. For example, if I am currently at 20% SOC and I am currently drawing 110kw from the supercharger, then my total would be (20 SOC + 110kw draw) = 130. If you would like to add additional factors such as outside temperature, current mileage etc, feel free. I am going to keep it simple for now. I will start;
2016 Model S P90D, 2020.48.37, MCU1, SOC + Draw = 130.
I had battery pack replaced in November 2020. There was no change in charging since it was remanufactured pack. I have 190k miles, charged all over USA. There are a hundred different charging situations. If u have a problem u have to keep records. I have a record of every super charge and battery problem. I documented that was using to many miles to go 50 miles. Almost 100. They checked pack, had 2 bad module.
Home charging and super charging are on different plants.
I have been pulling the SC data since Aug 2019 i take the numbers at when i first plug in and the numbers right before i disconnect. If connected to a paired stall or a urban SC i will not take the numbers down until it reaches the point where the speed limiting has been removed (like when it drops to 69kW on an urban SC), i also don't take a note if it is super cold/hot because those numbers will be off as well.
I plugged all of it into Excel and made a chart that i update about every week or so. I'm at 686 data points from chargers all over the place.
The change from MCU1 to MCU2 had no effect on my charging speed. 100% = 246 miles or 68.5 kWh useable (SMT)
Reactions: LostWages
Very informative! Thanks for posting. Which Model S do you have?
Ryanflynn
2021 MSLR to the moon
Apr 28, 2021
225
662
Venice, CA
21 model s long range 62f outside at 20% soc it was charging at 250kw
This thread inspired me to post more detailed results here:
