Surestart soft start
af88
185
28
Cali
7AoAbvV
Brand New, purchased two decided not to use it. This is for AC HVAC compressor to reduce the LRA and allow you to use your AC with Powerwall battery backup if you are below the total current capacity or near.
You can also use it on your compatible compressor just to reduce the stress on the compressor startup.
Model SS1B16-32SN
Asking $250 will ship
HankLloydRight
No Roads
Jan 18, 2014
12,822
10,834
Connecticut
Are these good for any compressors? How are they wired up?
We have two 5-ton A/C units and the lights dim when they kick on (which drives the wife nuts).
Any drawbacks?
af88
185
28
Cali
This is compatible with most scroll compressors. In terms of your lights dimming when they first turn on it should help as it basically reduces the Locked rotor Amp of the compressor, they advertise up to 60% but its really dependent on the age of the compressor etc it could be as low as 40% but it does from an electronics perspective reduce the LRA on startup so it should help. There is no downside, even if you don't have powerwalls having a soft start on your compressor just takes the stress off the compressor and helps it last longer really.
Where you run into problems is if you are at the edge of what the current your PW(s) are producing and expect this to get you under that range, b/c you are not accounting for other loads in your home. If your AC already works with your PW and you have flickering it should help if the condition is a lack of current for those lights. If it is other issues than it won't matter. I can ship it to you today if you want just paypal me.
af88
185
28
Cali
As for wiring it comes with instructions, pretty straight forward if you can follow an electrical diagram on your compressor to identify a few wires going to the run capacitor and contactor.
HankLloydRight
No Roads
Jan 18, 2014
12,822
10,834
Connecticut
Well, I do have a PW2, but it's only for backup power and the A/Cs are not on the essential loads panel.
I can definitely follow the schematics. I recently replaced the startup caps in both condenser units (very easy). I also got my EPA 608 certification so I could (legally) buy some R22 real cheap. :)
Let me run it by the wifey. We're selling this house (hopefully) within a month, so we might just let it go and let the next owner worry about it.
Reactions: captjoemcd
