Nice!I’m running 265/35r22 and 285/35r22 with zero issues.
22x9.5 +32 (front)
22x10.5 +40 (rear)
I might try those on a regular Lr Y but on a P it will be too tight. Especially when front wheels are turned 100%.So I just bought my wife a MYP and she want to use her current Vossen wheels if possibly. They are 22x9 +32 square. According to willtheyfit seems like they will fit well with only 2mm more poke in the front, and 6mm more inset in the rear. My question is around tires, will 265/35/22 fit in the front? I know it will in the rear. I thought I saw someone running this setup but can’t find the thread
Did you actually try this yet? My 21’s on the back are killling me please let me know if you had any rubbing?Wow, tight tolerances! (Edited) When my Pirellis are gone, I’ll move into a 265 front and 285 rear tire to gain some protection from curbs.
The pictures help immensely. I’m thinking you held some awkward automotive yoga poses to capture those shots...!
Lots of folks have done 265/285/40/21 with either no or very minimal rubbing in front. None in mine. I’m using 295/35 in the back with no problems at all. Ride is definitely a little more comfortable, and personally I think it looks better as well.Did you actually try this yet? My 21’s on the back are killling me please let me know if you had any rubbing?
I like the 40% as it give a little more vertical sidewall. Currently running MICHELIN PS AS4 265/40R21 fronts and 295/40R21 rears without issues.@Canyonero what is your complete set up? Front & Rears?
@Mursla No, I have not purchased new tires yet for the stock Übers. I’m currently on stock Gemini w stock continentals.
When I purchase new Über tires, I’ll certainly run 265 front w 285 in the rear…. The real question is to stick to 35% or jump to a 40% aspect ratio.
Continental DWS06+ 265/40/21 front 295/35/21 rear.@Canyonero what is your complete set up? Front & Rears?
Just find any ones you want with the stock size of 255/40R20.Curiously, what would be the issue with putting on 20 inch wheels for a Model YP?
I'm thinking of purchasing a Model YP to replace my M3 LR, and I'd need all weather tires that were half way decent. (Even in Maryland we get the rare shitty winter weather...)
Barring that, and because I'm a work and can't read the whole thread, what direct replacement tires without rubbing and speedometer issues could I immediately put on the MYP?
Thank you!Just find any ones you want with the stock size of 255/40R20.
Oh and make sure the load rating is adequate - at least 100V would be good.Thank you!
I've been driving with 265/40R21 and 295/35R21 on my MYP.
No rubbing issues at all. Ride is softer.
Range took hit.
How much did your range go down byI've been driving with 265/40R21 and 295/35R21 on my MYP.
Range took hit.
