My new MYP is getting creakier and has more suspension related knocking noises than I'd hope for only having 4500 miles.
It's the same sound a bad strut/shock or swaybar link. Sounds like both sides in the rear, and the front also has a knock/rattle/squeak when entering my sloped driveway. Left, right, center - seems like it's coming from everywhere. All of the dampers are dry, no oil leaks. I've checked as many bolts on the suspension as I can... everything seems fine.
The service center is 2.5hrs away, but I had mobile service here the other day and he said that re-torquing the subframe/other components can fix these issues.
Anyone been through this before recently? Should I get underneath, back off the subframe bolts, and re-torque them? I can't find a single component that seems loose, so I'm wondering if it's just in the subframe/body at this point and something needs to be re-torqued to fully-seat. I even rode in the rear "tub" while my father drove me around, and something is definitely causing a noise right behind the tub area. But it's not major, and sometimes can be hard to hear. Not willing to drive 5 hours round trip for the SC to not be able to find anything at the moment...
Is it possible some of this is just normal? I haven't checked the axle nuts... maybe something there?
