When you do a wheel swap, do you lubricate the threads with oil or anti seize? If you do, do you still use the full 129 ft-lbs of torque?
Any tips for making the wheel swap go little smoother for the DIY'er at home? I purchased the 19" lugano wheels from tirerack. I know I need to put the suspension in jack mode. I've done this many times in the past with Audi's, because I tracked those cars and had a dedicated wheel set for track use. Is it going to be hard to break the lug nuts loose on the car? I don't have a 21mm impact socket.
