Swapping wheels 20 inch from X to S. possible?
c
  • No, it does not fit. Not compatible between different models
    Votes: 1 33.3%
  • Tire size is not compatible
    Votes: 2 66.7%
  • Total voters
    3
Agree the wheels will fit. But you also have to consider weight ratings...the X is notably heavier and Tesla said they could not put my S wheels on my X for that reason. Of course, that will vary by wheel.
Yes. Great fit with my 2016 P90D.
20x9 +35 front. 255/40zr20 Mich A/S 3+ (Very slight rub on reverse @ full turn. Oversized by 0.3”. 245/40r20 is the correct size, same dia as 19s, but went 255 to get an almost square look)
20x9.5 +40 rear. 285/35zr20 Mich A/S 3+ (No rub, square look. Oversized by 0.2”)
There are other posts/pics like mine on staggered 20” MX on MS.
Hope this helps.
Reactions: mdevp
View attachment 322860 View attachment 322861 View attachment 322862 View attachment 322863 Yes. Great fit with my 2016 P90D.
Hope this helps.
Holy crap that looks SO good! I can't believe I haven't seen anyone else do it. But really on slight rubbing? That front wheel well looks mighty tight but great job!
Hope this helps.
Great Pics. If you have air Suspension, do they rub at all when you drive with the suspension at its Lowest point?
Yes, I have air suspension and did not notice any rub driving forward at lowest setting when I was testing on city /local streets with speed bumps (but of course had to slow down). Slight rub on reverse only at full turn. Same reports from other posts with similar setup except I have 255 in front vs 245 and BTW, I owe my setup to them and I couldn’t be more happier. Rub is in front fender well (see pix) but really not an issue for me. Hope this helps.
And thanks everyone for the likes.
Reactions: Latorre
View attachment 323573 View attachment 323574
Thanks what I love about this group. Everyone goes above and beyond, Thank You.
I could deal with a little rub at full tilt on the reverse. I put some big tires on my wives XC60 (yes, its a Volvo, smh) and it rubs a bit also, no biggie.
It's a true Tesla Master Mind.
I going with this set-up...
- Model X 20" Offset Slipstream Wheels
- Front: 245/40ZR20 (99Y) XL (Pilot Super Sport)
- Rear: 285/35ZR20 (104Y) XL (Pilot Super Sport)
Best,
Latorre
Reactions: PaulusdB
