Yes. In addition to possible issues with the bushings, the new bar also has more slop between the flanges where the bushing stops are:
The old bar wasn't this bad. However I already checked with UP and they said the distance between the flanges (663.5 mm) is "correct". Note that the mounts do have a small amount of side-to-side slop in the bolt holes, but not enough to eliminate the gap you see in the photo.
My initial theory was that the sound was caused by the bar moving left to right so that the flanges hit the bushings. However after removing the bar I noted there is a large amount of slop on one side (only) between the bar and the bushing. The other side has no slop at all. I haven't pulled the bushings off to measure everything yet. UP sent me a new set of bushings to try as well. I did note the replacement bushings have a slightly different design so maybe something has changed.
I suspect it's a defect in the bar though, not the bushings, especially if I'm not the only one with the issue.
(and just to be clear, I put the stock bar back on and there is absolutely no noise at all, the noise is definitely related to the UP sway bar)
I'm awaiting some Race Ramps before I dive back in and try to isolate what's going on. Jacking the car up and down over and over again is not my idea of a fun time
Luckily the sound is fairly easy to reproduce.
