is anyone else having a problem where you would swipe on the screen to view the tire pressure?
Mines is not responding I tried resetting but did not fix it. 2019.32.12.2
The wiper buttons work and everything else
Do you mean when the mic pops up let the 2 thumbs go? I did a reboot 2 times and also that power off one in the settings but still not working. At least if it’s a bug I’m not so worried I was just worried maybe it was my screen went badFunny. I had this exact issue two days ago. You can tell there’s a problem because the middle “dot” on the bottom left of the screen isn’t illuminated. It’s like the window lost focus (tech terminology).
Anyway, I stopped the car and held down the brake and two thumb wheels but noticed that the microphone coming up fixed it (middle dot turned white), so I let go of the buttons and never needed to do the reboot.
Pretty sure it’s a bug in 12.2.
I had the same thing happen yesterday. First I hit the backup camera button and I still couldn’t swipe. I then hit the microphone icon, it brought up the phone, I cancelled it and then I could swipe. This was the first time I drove the car after getting 12.2.is anyone else having a problem where you would swipe on the screen to view the tire pressure?
I’ve run into this bug in V9. Seems to happen when you swipe away from the phone call card then the call ends with that card still not open.
Hmm working fine on mine (just tested it) 32.12.2
@WilliamG I'll be sure to keep an eye out for it ... I am a bit a creature of habit and tend to check tire pressures each am just because..![]()
