Switched from perf 21's to Tesla's 19" winter package
Discussion in 'Model S: Driving Dynamics' started by cinergi, Nov 19, 2012.
  1. cinergi
    cinergi Active Member
    MA
    Just got my tires swapped today. The ride is significantly quieter (not like it was loud before) and the bumps are softer (again not like it was a harsh ride). I haven't pushed them yet (too new) or observed wet conditions, etc ... but I'll report on that.. as well as impact on highway range. I'll use this thread to discuss the differences. So far, I'm kinda liking the even quieter and softer aspects. However, I'll probably miss the traction once I begin pushing on them :smile:
  2. shokunin
    shokunin P85 & M3
    Irvine, CA
    I'm assuming you're running the 19" and Pirelli's?
  3. cinergi
    MA
    That's what I ordered and while it's obvious they're 19's, I haven't actually checked the tires ... I should do that :smile:
  4. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Did you order the package from Tesla, or something from Tire Rack or what?
  5. cinergi
    MA
    From Tesla.
  6. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    I drove on the 21's for a week, then switched to the 19's with Pirelli's. The Pirelli's must have had some sort of film on them at first, they were really slippery for the first week even on dry roads (I couldn't spin the tires on my regular model with the 21's). They seem pretty good now; including good though not infinite traction in wet (which we are having a LOT of at the moment).
    Of course with that slippery week in the middle, it is hard to compare the two tires directly. Plus I only drive the S sporadically and intermingle it with the Roadster. It does seem like the steering isn't quite as sharp with the Pirelli's. Haven't noticed a lot of other differences though.
  7. jerry33
    Texas
    New tires still have mold release on them and the bead area can still be wet from the mounting lubricant. Generally it's a good idea to go easy on them for the first 300 miles. The mold release on real performance tires wears off almost immediately, which is why you never noticed on the 21". And don't forget to have the tires rotated around 1500 miles so that every tire will have a turn on the drive axle early in it's life (helps prevent uneven wear later in life).
  8. Randy
    Randy New Member
    United States
    I currently have the hi perf 21's and when I reach 70mph or above there is a noticeable humming noise in the right rear of the car.
    I have brought the car to Tesla and they verified the noise. I suspect it may be the tire on that side of the car but not sure.
    Any experience with noise from these tires?
  9. jerry33
    Texas
    Noises in cars are very hard to pin down because of both the reflective surfaces (glass) and the path the sound travels. In the worst case you have to put microphones in suspected locations to actually determine the source of the noise. I actually had an instance where the complaint was tire noise but the real source of the noise was the roof rack.
  10. William13
    William13 Active Member
    South Bend
    Did you check the tire pressure, cenergi? The 19s are supposed to be filled to 45 pounds as apposed to only 42 for the 21 inch tires. When I properly inflated my tires the ride became very similar to the 21 inch ride. Of course cornering and acceleration suffered.
  11. goyogi
    goyogi Member
    ::Silicon Valley:: ::Home of Tesla::
    I changed out my 19s for 21s yesterday. I was supposed to have 21s but ended up with 19s upon delivery. I did notice a slight noise difference but nothing bad. Butt-o-meter didn't notice anymore harshness.
  12. bosgig
    bosgig Member
    Metro Boston
    Cinergi--please update with any thoughts re. your decision to go with 21" perf + 19" winter package. Is your driving experience with both a reaffirmation of the decision or, alternatively, any regrets? Same city--same weather, and I'm very close to finalizing with the same wheel decision.
  13. cinergi
    MA
    Hmm. I can't comment on the standard 19 tires obviously ... But I can tell you I miss the fact that I can't put down 100% power to the ground anymore. Are you getting perf? If not, that won't be an issue. I like the ride quality. I haven't done any tight turns yet (again that wouldn't be representative of standard 19" tires). I'm probably at the point where I have enough mileage on them to do some tests. Maybe I'll go for a ride tonight :) Been meaning to collect some 19" range data as well ...
  14. bosgig
    bosgig Member
    Metro Boston
    90% decided on the performance. If I were to do the standard, I wouldn't do the 21" upgrade, but rather stick with the 19's. I know others have passed on the 21's with the performance model even though there's no credit for doing so, mostly just to avoid the incremental cost of the extra set of wheels/winter tires and the hassle of storage and swapping in and out. That's really why I ask, although I'm definitely leaning towards the 21's + 19's for winter. Thanks for sharing your experience.
  15. cinergi
    MA
    Just got back from a 100 mile jaunt :smile:
    For general driving, you don't pay much of a penalty ride-quality-wise for 21's vs 19's. You pay a little bit in range (I couldn't tell from this evening's ride -- too many hills in the area and the winters probably aren't as low rolling resistance as the standard 19's). But the 21's get you a lot more traction (both accel/decel) over the 19" winters. Sharp corners are much softer and less of a "car on rails" experience (almost feels sloppy).
    Either way, 19" all-season with RWD will be a little rough in the winter (not impossible, but I think you could definitely end up stuck or not stop as well as you could on winters). You'll want winter tires anyway. Tires are the only thing between the car and the road -- I'm a firm believer in the value of even the cheapest winter tires over the best all-season's.
    Getting an extra set of rims pays off in a few years and you won't have issues with damaging the tires from swapping them (e.g. belt-shifting) or balance issues, etc ... You're at your own schedule for putting them on if you get a jack and whatnot (no more last-minute-can't-find-anyone-to-mount-your-winter-tires issues) ...
    Hope that helps!
  16. bosgig
    bosgig Member
    Metro Boston
    It does. Thanks. I was thinking the same thing on needing winter tires anyway given the rwd, so the hassle factor and incremental cost issues at that point pretty much become moot. Sounds like a good way to go. Thanks again.
  17. jerry33
    Texas
    The best severe-service all-seasons are really about 90% as good as the best winter tires. Cheap tires (winter/summer/all-season) are just cheap tires. What I think is that you've never had a set of good all-season tires (like Nokian WR-g2).
  18. cinergi
    MA
    Cool! It's been a while since I've used all-seasons ... have they gotten better recently (6 years) or have I just never used good ones?
  19. JakeP
    JakeP S P4996 ==> P02547
    Bradfordwoods, PA
    Jerry33, I looked into those Nokian WRG2s after you recommended them earlier...they do look sweet, but aren't (currently) offered in 245/45R19, unfortunately. Hopefully that will change after the Tesla business on their studded Hakkepeliitas.
  20. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Maybe writing Nokian directly and asking them to produce the correct size might help. It sounds like they would be the perfect one tire only solution for people in areas that get minimal snow.
