Just kidding. Every other automotive forum of which I have been a member has had lengthy discussions about this. Thought I would throw one on hear for good measure.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Just kidding. Every other automotive forum of which I have been a member has had lengthy discussions about this. Thought I would throw one on hear for good measure.![]()
Can't we debate hydro electrons v.s. solar electrons v.s. nat. gas electrons instead. I've always found the car to perform a bit stronger on hydro.
oh, smac....I think mine is running on French Nuclear tonight...
.....I'll see if I get any extra motor wine tomorrow.
:redface::redface:
Synthetic remains viscous at a lower temperature and has a longer shelf life.
I'm sure you meant to say less viscous. All conventional oils become more viscous at lower temperatures and lose viscosity when hot.
Coal and nat gas have all that carbon that can build up in the wires. Coal is a bit worse then gas. When I switched to Solar it took a few charges to flush all that gunk out of the battery. I find solar better than hydro, as they aren't as damp and are less likely to clump.Can't we debate hydro electrons v.s. solar electrons v.s. nat. gas electrons instead. I've always found the car to perform a bit stronger on hydro.
Synthetic oil is clearly superior, and anyone who says that conventional oil is better needs to do their research.
PLEASE tell me that you aren't using coal-fired electrons to drive your speakers! Not only does it muddy up the bass, it also causes the tweeters to roll off severely on the high end! The warmth of the speakers is totally gone, the soundfield won't image, and you're left with what sounds like a bad tinny reproduction of some old wax-cylinder recording!What's awesome is that you sound almost exactly like various audiophile reviewers talking about their audio cables, except they're actually serious.
Every audiophile who has experimented with better power cables has heard the performance advantage they offer. Indeed, the amount of improvement can be astounding, often transforming a system from good to amazing. As audiophiles, we trust our ears but it’s hard to understand how replacing just one short link in a long chain of the power delivery system can have such a dramatic impact. The following article is intended to answer those questions.
Every wire type (I am talking about the metal itself) has a specific sonic characteristic. Silver, copper, brass, gold and others all "sound" different. The difference in sound is not related to conductivity capacity because we adjusted the sizes during testing to account for this. Each of the metal's inherent "sonics" can be ameliorated by careful adjustment of the other materials used in the construction of the final cable. We have a warehouse full of various prototype cables that never made it to production. Some of these use a relatively small wire size of ~18ga, that sounds surprising full in the bass. Intuitively, you might think that a small wire would sound thin in the bass region. This is not always the case. Conversely, we have some cables with wire as large as 1gauge that sound powerful in the bass but are also flabby and irregular sounding. So, just increasing the wire size is not the easy answer that some might think.
Hey, it's not just audio cables. Here's a company that swears that putting in their power cable will improve the sound of your audio components:
