I think there was a post a while back about Quietcool whole house fans. I'm not schilling that vendor, but they use variable speed ECM motors instead of what appears to be a PSC style motor on the Triangle whole house fan. I think you should check out ECM for the flexibility to run at lower speeds. For disclosure, I don't have a whole house fan, and I don't like them because of my allergies.
Based on the spec sheet of Triangle's PMTR-CC3623 (motor used in the fan that sorka linked), says it is 8.2A at 115v on high ... so it's around 950w. The low setting isn't described, but since PSC motors aren't linear, I'd expect low to pull over 600w.
The largest
Quietcool ES7000 ranges from 276w up to 1,100w. But I really don't think you get much bang for your buck with these attic fans on their high setting. So it's likely you'll just use this thing on medium for a few hours around sunrise and sunset to move some cooler air from outside inside to get some cooling that is more efficient than an AC.
My 2 stage Lennox + internal air handler takes 1.7 kW. IMO, I'd rather just run my ACs if the trade off is a 1kW whole house fan running on high trying to blow air around.
