'T' on charging cable flashes red.
mnsweeps
555
135
Los Angeles
I used this charger in my garage for my Model 3 and Model Y. When I start charging I get 30 miles/hour .. after a few hours, I see the rate go down to 15 miles/hour. I have a similar 240v outlet and charger on the other side of the garage and thats works fine.
I went to check the charger and see the 'T' flashing red 4 times but charging continues at 15m/hour. Is this a grounding issue on that particular ground outlet?
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,383
4,494
Kaneohe, HI
Sounds like these people know what they are talking about. But please, please, PLEASE, don't try to fix this yourself UNLESS, you really, really, really know what you are doing. We don't want your last post here, to be your LAST POST.
Reactions: Reborn and mnsweeps
yerEVan
882
803
Near Philly
Right. I should have mentioned that. Definitely get an electrician.
Reactions: Akikiki
namikun
63
47
CT
This happened to my mobile connector, too. I would also see charging errors notifications on the screen. Tesla ended up replacing the unit under warranty.
Gasaraki
1,525
1,008
Syracuse, NY
i dont have any charging errors on screen
This is because the mobile connector is ramping down the amperage available to the car. The car doesn't see it as an error because it's technically not an error to the car, the amperage is just lower.
You should have someone check your 14-50 socket to make sure everything is still tight. If possible try the mobile connector in another socket of the same type and start charging to see if it's the mobile connector.
Reactions: mnsweeps
