T Sportline is proud to show it here first prior to it's SEMA SHOW debut in Las Vegas on November 1st.
We always felt the Model X could use a little more umpf. T-Largo is the design solution.
The T Sportline T-Largo is a sleek and sporty individualization program for 20 lucky owners. It truly gives the Model X a stronger appearance against its luxury class peers. With our desire to bring the best in quality and design to market, the T-Largo aero parts will be manufactured in an autoclave process with prepreg carbon. This will add minimal weight to the Model X, and provide the strongest of parts that will withstand the time of ownership. Our wide fender arches add ~50mm/2.0" of width to the front fender and ~75mm/3.0" to the rear fender. Rocker panels (side skirts) are also designed and widened to transition from front to rear.
Finishing aero parts will include a newly designed rear diffuser, oe factory wing cover and a 3-piece trunk wing.
Each T-Largo will include our TS120 T-Largo directional wheels (22x9.5" front and 22x10.5" rear) with a turbine inspired look using Tesla factory oe 22" Pirelli Scorpion tires in 265/35-22 front and 285/35-22 rear. Each wheel is forged. Each wheel is specific to an axle (hence directional) and made locally. Like our other wheels, the TS120 T-Largo will accepts factory lug nuts and TPMS. The TS120 T-Largo wheel set is about 5% lighter than a factory 22" Turbine wheel set.
The T-Largo concept will be displayed at the Pirelli Tires Booth right outside the tire & wheel hall (South Hall) at the Las Vegas Convention Center, Tuesday Nov 1 to Friday Nov 4.
