TACC following distance
KeithT
My Model 1
Mar 9, 2020
38
14
New Zealand
I think under the AutoPilot menu there was a variable that set the following distance (I had it set to 5 which seemed to obey the '2 second' rule at higher speeds). But now I can't find it - has it been supplanted?
I did notice a few revisions ago that braking got more aggressive and it didn't seem to start braking until later. I just thought the algorithm had changed but maybe it now has a built-in 'following distance' that isn't what I would have chosen.
Thanks
Reactions: Mr X
JATinNH
49
31
Salem, NH
I noticed it has disappeared from the Controls menu as well. It used to be in CONTROLS>AUTOPILOT but is no longer there. Owner's manual still says its there. Of course the right scroll button is the shortcut, but you're not losing your mind. ;)
KenC
3,278
2,993
Maine
Thanks
My own observation is that each increment is ½ a second, so a "5" would be 2.5secs.
Mikeydeek
142
49
Ottawa
Thanks
2 second rule has kept me alive! I keep mine at 7 but sometimes still feels too close! The option is still in the autopilot options for me.
KeithT
My Model 1
Mar 9, 2020
38
14
New Zealand
Press the right scroll wheel right or left to adjust follow distance.
Thanks, either didn't know or had forgotten about that. I followed your advice and found out that the distance was set to 3! I had it at 5. Not sure how it got changed but this is probably the reason why I suddenly thought that it's leaving the braking too late. Will test though.
Reactions: lUtriaNt
SlimJim
853
640
I usually leave it on 2.
3 seems to brake way too early and cars behind me do not expect that. Almost got rear ended.
Candleflame
2,390
1,100
QLD, Australia
yeah, 7 is too close for dual lane rural highways where you have to tail behind trucks etc for a bit. There should be an 8 setting which is as far as it lets you.
novox77
1.21 Gigawatts
Nov 25, 2017
1,632
3,532
NH, MA
wow. I have mine set at 1 and I feel like it still leaves too much gap. Here in the Boston area, you'll get perpetually cut off if you leave any room between you and the next car. and the people behind you get pissed cause you're "slowing down the lane" letting people in.
Reactions: JohnNick72
lUtriaNt
614
541
Los Angeles
the main reason i set this setting to high (5 or more) is because i want the car to regen more than use the friction brakes. i dont want brake dust getting on my wheels.. :p
PDX-JP
45
24
Portland
that’s interesting. I have mine set at 3 because anything more and people will cut in front of you resulting in hard breaking. If not for that factor I’d be at 4 or 5 for a more genteel experience
Reactions: lUtriaNt
KenC
3,278
2,993
Maine
I vaguely recall when I had my Volt, that I was able to measure what I thought was a normal follow distance in Boston, and it was about 0.6secs. Anything more, and Bostonians would dodge in front of you for the gap. A "1" in the Tesla should be 0.5secs, so it should be about normal for Boston driving. Haven't tested it myself, but I like to use "3" and not worry about fools who barge the gap.
KenC
3,278
2,993
Maine
Strange. A "7" should be about 3.5secs. You're saying that's too close following a semi? I don't follow semis because I don't want a pebble to crack my windshield. I wonder what a safe distance would be to prevent pebbles. How long do they stay up in the air, would be a good question for high school intro physics class.
GtiMart
556
414
Quebec City, Canada
I'm beginning to think that it depends on whether you have EAP or not. I personally find the TACC and Autopilot slows down too much when approaching a vehicle on the highway. Even at a setting like 3 it slows before I have time to signal and change lanes. I am forced to put it at 1 or 2 because of that. I don't want to hog the left lane for too long you see... If I had EAP, it might change lanes instead of slowing?
On rural roads where you cannot pass, or only in certain areas, I do want to stay farther away but I want to be able to pass when it's legal so I can't be that far away. Even then, I have to say I don't quite understand the "21" request :)
Candleflame
2,390
1,100
QLD, Australia
7 still gets you windshieldrockchips, so yeah its too close. i should know, where i live its 1300km to the next dual carriageway.
Reactions: KenC
