TACC - Set to Current Speed?
Discussion in 'Model 3: User Interface' started by SomeJoe7777, Apr 6, 2018.
  1. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    Ran into a dilemma this morning that appears to be a fairly large design problem.
    Surface street, normal speed limit 45 MPH. Approaching school zone, speed limit 25 MPH when the yellow lights are flashing (they were). I like to set TACC in school zones like this to prevent me from going above the posted speed (cops frequently watch this street and this school zone). I tried several times to set TACC to 25 MPH, and I can't figure out how to do it.
    Every time I tried, no matter if it's a half-click down on the stalk, full-click down on the stalk, click and hold, etc., TACC always set itself to speed limit + offset = 50 MPH. There isn't enough time to press and hold the "minus" button on the display 5 times to get the set speed down to 25 MPH before I'm going way too fast.
    I the S, you can set TACC to the current speed regardless of the speed limit by a half-click up or down on the cruise control stalk, but no such way to do it in the 3.
    Am I missing something here or did Tesla just b0rk this interface?
  2. Shygar
    Shygar Member
    Pleasant Hill, CA
    The online manual in the car goes into details about this. I was just reading it today. I think if you are going below 45 MPH there has to be a car in front of you in order to set it.
  3. seabie
    seabie Member
    Columbus, OH
    I run into the same scenario everyday on my commute. 35 mph speed limit but based on the time of day drops to a 20 school zone. Total speed trap too as the road is four lanes wide and the local police regularly setup an assembly line of ticketing.
    Engaging TACC or AP jumps straight to 40mph (+5 offset setting) and I have to quickly tap the set speed down to 25. Having the scroll wheel control update will help but it still feels strange having the car lurch forward then slow down
  4. SomeJoe7777
    Houston, TX
    Ya, there definitely needs to be an interface change here.
    In the S & X, the way it works is:
    • Half-click up or down on cruise control stalk sets to current speed, regardless of anything else.
    • One full pull rearwards sets speed to either:
    1. Last set cruise speed if your speed is below that
    2. Current speed if your speed is above that
    3. Speed limit + offset if you don't have a previous set cruise speed
    • Full pull and hold sets speed to speed limit + offset, can be used even while TACC is already engaged (useful for resetting speed downwards or upwards when the speed limit changes)
    • Double-pull turns on autosteer
    I would say you could do similar in the 3:
    • Half-click down on stalk sets to current speed
    • Full-click down on stalk sets to either:
    • Full click-down and hold sets to speed limit + offset
    • Double-half click is current speed + autosteer
    • Double-full click is the same as the single full-click described above + autosteer
    • Double-half click when TACC is already active just adds autosteer without changing current TACC settings
    Right now, there's no differentiation in the 3 between a half-click down and a full-click down, they both do the same thing. That's where this interface element could be added.
  5. Tiger
    Tiger Active Member
    Estonia
  6. ratsbew
    ratsbew Active Member
    O'Fallon, IL
    Wait, wait, wait.....you're telling me that if I'm doing 30 in a 45 and turn on TACC the car will jump up to 45mph???? That's ridiculous. I want it to hold the speed at the time of engagement.
  7. SomeJoe7777
    Houston, TX
    Yes, that's exactly what I'm saying and that's why it's a problem.
  8. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Yup, very annoying. At least with the scroll wheel I can now quickly scroll down to get to my desired set speed. Before I had to frantically tap on the tiny icon on the screen.
  9. ratsbew
    O'Fallon, IL
    I read the manual and it's confusing. It says "When driving at your desired speed, set thecruising speed by moving the gear lever fully down once then releasing." And two pages later it says "Traffic-Aware Cruise Control makes it easy to cruise at the speed limit. You can cruise at the speed limit that is currently being determined by Speed Assist. To do so, move the gear lever fully down once then release. When you release, your cruising speed is set to the speed that is determined by Speed Assist."
    The same physical action seems to have two different outcomes.
  10. ratsbew
    O'Fallon, IL
    The other thread mentions that you can do a half press down to set current speed.
    Anyway, in no case should it accelerate. That's asking for "unintentional acceleration" lawsuits. The only time it should jump speed is if you tap on the speed limit icon to set the speed.
  11. Az_Rael
    Palmdale, CA
    In practice, if the car knows the speed limit, pulling down on the stalk will auto set TACC at the speed limit even if you are driving slower. If the car doesn't know the speed limit or you are driving faster, it sets at your current speed.
    I haven't tried a half press. That might be new functionality.
  12. SomeJoe7777
    Houston, TX
    That works on the Model S and X, but not the 3.
  13. seabie
    seabie Member
    Columbus, OH
    Yes I agree with this summary. My new trick with the school zone scenario I detailed earlier in the thread is to engage TACC/AP just before the car figures out the speed limit so I can set it to my current speed.
    The scroll wheel update did improve the effort and speed to quickly correct the set speed but this is all still less than optimal. I don’t mind the car jumping straight to the speed limit plus my offset but if so it needs to see the flashing school zone lights :)
  14. GDNTX
    GDNTX Member
    Dallas, TX (Far North)
    Don't have my 3 yet, but one other thing you can do is to touch the speed sign on the screen. This is talked about in the manual somewhere. Touch it and it will set to the speed recognized and displayed. I have no idea though for a school zone how it knows if it is normal speed or school speed. So on a week day does it set for 20 in the school zone and on the weekend stay at regular speed? It's reading the signs right?
  15. seabie
    seabie Member
    Columbus, OH
    No it does not read signs and has no idea the school zone is active. So in my use case it thinks the speed limit is 35mph (which is correct unless the school speed zone is active during the day).
    Speed limit is based on GPS and is pretty accurate ignoring dynamic stuff like construction zones, school zones, etc.
  16. SDKoala
    SDKoala Model 3 LR RWD
    San Diego
    This is a big annoyance, especially with the speed limit markings being inaccurate in some areas. In my residential neighborhood with a 25 MPH speed limit, the GPS thinks the speed limit is supposed to be 55 MPH. If I engage TACC when on the road by myself, the car starts to accelerate to 55 MPH unless I quickly set the speed lower. It's impossible to avoid the lurching forward.
    This is a big safety issue and the one time the claim that "the car accelerated by itself" could actually be at least partly true. Is there really ever a reason why TACC shouldn't be set to your current speed by default? That's how every other cruise control system I've ever used works.
  17. mt2
    mt2 Member
    Chicago Area, North Burbs
    I see the last post here was May 1. I can confirm that as of firmware 2018.34.1 3dd3072 (9/7/2018), this issue still has not been fixed.
    Things I've tried:
    • Push the stalk down half way versus pushing it down all the way. I was trying to copy the behavior seen in the S and X, as above. But, both actions set the TACC to the suggested speed (inside the grey circle). So Model 3 still behaves in a way similar to the other two Teslas but varies in one critical feature.
    • Turn off the Speed Limit Warning. I was actually trying to turn off Speed Assist on the theory that it's 'assisting' TACC. But, apparently, you can't turn off Speed Assist, so turning off the warning had no effect. (Side note: with the warning turned off I could not adjust the relative speed it's supposed to warn me at -- but TACC still used that setting. So if you don't like the warning but do like the relative speed setting for TACC, you have to turn the warning on, sett the offset, then turn the warning back off. Wtf?)
    • All combinations of the above.
    This is a huge issue for me. I consider it a safety issue. I find it bitterly ironic that the manual often reminds us that the driver must remain in control of his car when TACC is engaged -- but then they take all control of the speed away from the driver when engaging TACC. Go figure.
  18. Enginerd
    Enginerd Member
    Savannah, GA
    Let me suggest how it should work (hello, Tesla, is this thing on?). Before engaging TACC, the "set speed" is shown in the little gray circle, and the right scroll wheel doesn't serve any purpose. Simply allow the right scroll wheel to adjust the "set speed" before engaging TACC. TACC always goes to the indicated "set speed", so just let me change that to the # I want.
  19. sduck
    sduck Mr. Duck
    Nashville TN
  20. ratsbew
    O'Fallon, IL
    I think that the best solution is a press down (half or full) to set current speed. HOLD the stalk down for 1 second to accelerate up to the "speed assist" speed...or tap the speed limit icon.
    Likewise, with EAP, double tap for current speed, double tap and hold for the speed limit.
    People who don't read the manual will be none the wiser about the hold feature and will just use the scroll wheel to accelerate.
