Tail Light alignment
Sebat4
117
51
New Jersey
Should the trunk part of the tail light be align with the side both side tail lights or should the trunk tail light be little pushed in? I have no other MY to compare with my MY and I'm trying to figure out if that is something that should be this way or not. Anyone minds posting a picture of their tail light. Thank you.
jf64k
483
538
Los Angeles
TomServo
1,656
1,093
Belleville IL
My right assembly is almost perfect, the left one looks a little worse than yours.
My problem is the charge port sit flush with the car and is PERFECTLY fitted, I mentioned this when I dropped off my Y for its post-delivery SC visit and I hope it can be adjusted without messing up the charge port. On the other hand, maybe it's the light assembly mounted to the hatch that needs to be adjusted. Fingers crossed they get it right.
Zythryn
Model Y custom Warming Stripes wrap.
Mar 18, 2009
2,187
1,286
Minnesota
My understanding is there are spacers that can be trimmed to allow the taillights to sit a little close to the car body. This makes some adjustments easy.
LevelHeaded
530
419
Salt Lake City, UT, USA
Beware. I had my taillights adjusted at the SC. They got them to align a bit better, but after I took it home I noticed that the right tail lights were catching each other when the hatch opened after the adjustment. Took it back to the SC. They changed the hatch alignment to “fix” this new issue. Afterwards, the gap between the roof and hatch glass was big enough to allow water into the car during car washes. Now it’s back at the SC again, and they’ve had it at a body shop for 11+ days to fix the new hatch alignment issue.
I wish I would’ve never complained about the taillight alignment!
Berkshire1
111
147
Egremont, MA
Taillight alignment seems to be a common problem. I was told it was "within specs". If true, then the specs should be changed as it is obvious to a 10 year old that there is an issue. That being said, I decided to live with it, as is, for the reasons stated by "Levelheaded". Sometimes the pursuit of perfection just leads to more problems. Overall, the car is fantastic. I will never purchase an ICE car again!!
Reactions: ilikemypizza
LevelHeaded
530
419
I forgot to mention, they also damaged my matte PPF on the tailgate and scratched the paint under it while adjusting. They’re fixing the paint at the body shop but I’ll still have to pay out of pocket to have the PPF redone on the affected section
phoha21
127
43
Maryland
same thing happened to me... my MY is at the SC today (again) to address the tailgate/taillights, very large gap on the driver side and between the glass, plus the common rear seat folding issue
luckily they had an older MS P85D avail as a loaner, although it was locked in chill mode
Blucenturion
305
139
Humboldt Co., CA
I submit mine as the worst (2021, Feb Delivery). If I should decide to take this in to Chico CA SC, it will be a 4 hr drive from where my benighted life has placed me. And I must be there at 10:30 a.m., latest.
