Tall Mods - Modifications to the Tesla Roadster for Tall Drivers
Discussion in 'Roadster 2008-2012' started by zylstra, Feb 10, 2012.
Tags:
  1. zylstra
    zylstra Member
    I'm 6'6". As most tall drivers have done, I've removed my visors, and exchanged my stock rear view mirror with the Sector 111 Micromirror, which I tinted. Here are a couple more ideas that I've implemented:
    Roof Spar
    I first tried the simplest approach: I made a heightened roof spar from a strip of aluminum that I cut with a Dremel and bent into shape with some clamps and monkey wrenches.
    Custom Seat
    But in addition to getting the roof out of my hair I wanted to sit lower so I could have a better view. So I ordered a new seat and cut out the bottom, which lowered me by an inch.
    Here's a view toward the front:
    And toward the rear:
    I also wanted the seat to recline further since the stock position is so upright. So I inserted some aluminum spacers to raise the front of the seat rails, which I then attached with some longer bolts:
    Right side (passenger's side?) of driver's seat:
    Left side of driver's seat:
    I also wanted to be able to hold my head upright without it bouncing against the headrest, and my shoulders to be unslumped, so I inserted some extra padding behind the top center of my seat.
    The wonderful guys at the Tesla design center helped with cutting out the carbon fiber roll bar cover so my head wouldn't hit it now that the seat was reclined.
    My next post shows my last mod (done just last night).
  2. zylstra
    zylstra Member
    Accelerator Adjustment
    I wanted my right leg to be as stretched as possible when I am driving so I adjusted the accelerator back an inch. Now it barely hits the frame, but I still get maximum acceleration. Three bolts attach the accelerator box (plastic with electronics inside) to the pedal box (sheet metal). I loosened the forward bolt and replaced the two rear M8-1.25x40 bolts with M8-1.25x50's (60's won't fit). I tilted the rear part of the accelerator box down so that I could insert two .5" spacers - one for each rear bolt. In the following photo you can see the bolts from under the hood.
    Here you can barely see the one of the spacers from inside the pedal box (inside the passenger compartment). One o'clock is rearward.
    And two before, and two after shots:
    Please let me know if you have any questions. I have extra spacers and bolts for the driver's seat reclination adjustment. Let me know if you would like to try it out. I highly recommend it, even for shorter drivers. I'm in Hermosa Beach (Westwood too) near Los Angeles.
  3. PV4EV
    PV4EV Supporting Member
    Area 51(a) / UK
    Congratulations on your dedication to making a Roadster work for your height !
    I'm 6'2 and can just about shoehorn myself in. But back in December I posted the following roof options, which included a photo of a Gullwing Elise roof - made in a small batch in 2004/5. Apparently these were a very popular idea, but no one actually managed to get around the water leakage problems, including what to do when you open the hatch with a roof covered in rain that then drops into the car. There was also some flex in the 'T' section which could cause the t-bar to crack. I am sure there's a design solution for this, but it will need some investment of time n money.
    I also cannot see the top of the speedo, so I made a very compact digital speedo using good old fashioned dot matrix LED displays. I wanted it to be right in line of sight and not off centre, plus have auto dimming etc. It can be positioned between the two main dials without obscuring anything, or neatly fitted in the 'grove' of the binnacle ontop of the dash.
    Would love to have this gullwing on a Roadster though …
