Tampa Supercharger
Discussion in 'Florida' started by joer00, Mar 1, 2014.
Tags:
  1. joer00
    joer00 Member
    Tampa
    Just took a look at the map and Tamps is now on marked as "coming soon". Time to start speculation and look for permits ? I think the Branden Mall was mentioned once and this would be a perfect location. Good restaurants there and anything else one needs for a break.
  2. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Time to start a new thread..... :-D
    I heard today that permits are in process for a Tampa Supercharger. Anyone feel like hunting down the location? Assuming Hillsborough County....
    I asked someone at Tesla if it was Brandon Mall and got a negative on that location. I'm guessing that the I-4/I-75 interchange makes the most sense but don't see any obvious sites. Of course, it could be a couple of miles from the interchange.
  3. jrreno
    jrreno Nothin' left to do but smile, smile, smile
    Sarasota , Florida
    That agrees with conversations I've had with various Tesla folk in Orlando and Tampa. Close to the interchange but not at the Brandon Mall.
  4. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    Although Larry Chanin seems to believe it is going elsewhere, I think the Brandon Crossings Shopping Center on the west side of the I-4 & State Rd 60 (Adamo Dr) intersection would be an ideal location. Lots of excess parking in the center, and lots of food and shopping choices within walking distance.
  5. Larry Chanin
    Larry Chanin President, Florida Tesla Enthusiasts
    Sarasota, Florida
    Agreed I don't think it will be at Brandon Mall, nor at Brandon Crossing, although I think they are both good locations. However, I do believe it still will be in the Brandon area. Regency Square Mall is also a good candidate. It's at the intersection of I-75 and state road 60, a few miles from I-4.
    I haven't had any luck finding a permit. The Tampa building permit search only allows for address, permit # and parcel #. So far guesses at addresses have been unsuccessful.
    Larry
    - - - Updated - - -
    Steve,
    Brandon Crossings is very close to Regency Square. Its west of the intersection of I-75 (not I-4) and State Road 60.
    Larry
  6. Ufrugger
    Ufrugger Member
    Trinity, FL
    #6 Ufrugger, Mar 18, 2014
    Larry those locations on the map would be in Hillsborough County and not the City of Tampa (though the city boundary is close at Orient Rd.) The Hillsborough County Permit Search website is HERE.
    Scroll down the page and click on the 'Check/Research Permits' link
    The best method I've found is to search under the "Look up Licenses/Permits/Projects" column and click on "By Address". Once there you can simply type in a street name and a 'From Date'. If you select 'For Projects' it seems to limit your results. I've already done this for a most of the main roads in this corridor, but maybe I'm not reading the permits correctly (some will make it easy and tell you 'Roofing' or 'Dillards', etc.)
    Obviously particular parcels can be searched using the website, but I'm working on the assumption that the location and/or parcel with the eventual superchargers will front a main/popular roadway. Searching the road allows you to cover much more ground.
  7. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    Larry,
    Thanks for the I-4 error correction. I'm home sick today - obviously the drugs are good....
    I'm familiar with Regency Square. Access in and out off of RTE 60 is horrendously backed up all the time. Once you are in the center, traffic patterns are awful, and parking always seems a mess. Because of those issues I have not been there in many months. Maybe it is better now.
  8. Ufrugger
    Ufrugger Member
    Trinity, FL
    Unless someone here has specific information for the above mentioned locations, might I suggest a location just a tad further south. I'm assuming a couple of things with this location, specifically that the supercharger doesn't need to be as close to I-4 as possible & 85KW Drivers originating in Tampa can reach the other superchargers without the need for a Tampa charge. Again, this is all speculation, but I feel the SE corner of Bloomingdale & Providence Rd. has potential (maybe the NE corner as well). Then again, I may have missed the thread discussing all of this :)
  9. Larry Chanin
    Sarasota, Florida
    Thanks Dan,
    The link you provided doesn't work for me. I did find a Hillsborough County permit search, but it doesn't seem to have the 'From Date' searches that you mentioned.
    I've done some address searches, but no luck.
    Larry
    - - - Updated - - -
    Dan,
    What specific host locations and amenities did you have in mind at this location?
    A location off of I-75 and near I-4 is strategic because it facilitates travel North and South on I-75 between the existing Ft. Myers Supercharger and the "Coming Soon" Supercharger in the Gainesville/Ocala region. If that Supercharger is also located near I-4 it facilitates travel East and West between Tampa and Orlando.
    Ideally the placement of Superchargers must avoid situations where only 85 kWh batteries can comfortably travel between locations. Ultimately, the design must be dictated by the range of 60 kWh batteries.
    Larry
    - - - Updated - - -
    I hope you're feeling better soon.
    Others had similar criticism for the Brandon Town Center Mall location. I suspect that Tesla is balancing the Cons of traffic issues with the practical issue of finding cooperating host locations with the necessary amenities that are strategically located off of major highways.
    Larry
  10. Ufrugger
    Ufrugger Member
    Trinity, FL
    #10 Ufrugger, Mar 18, 2014
    Note: I changed my post above to include the correct link to the Hillsborough County Permit Search Site.
    I would like to expand on my reasoning for the location south of the Brandon Blvd./Adamo Drive. My statement regarding 85kWh owners originating from Tampa being able to reach all of the nearby superchargers is still correct, and is also correct for 60kWh owners. From this location at the SE corner of Bloomingdale & Providence Rd. (which is only 5 miles from the Brandon Town Center location) the distance to nearby superchargers are as follows: Gainesville (TBD) 135-145 Miles, Port Orange 138 Miles, Ft. Myers 130 Miles, and Port St. Lucie 146 Miles.... all reachable in a 60kWh.
    Having a location as close as possible to I-4 doesn't provide as much benefit as one would think. When I think of the typical road-tripper that would be passing through Tampa, the majority of the Westbound traffic on I-4 would be heading south. An Orlando driver wanting to travel to any location north of Tampa would have no problem reaching their destination. Any traveler from SE Florida wanting to get to Gainesville/Tallahassee would take the Ft.Myers-Tampa-Gville route or the route up I-95. The distance from Port St. Lucie supercharger to Gainesville location (approximate) is about 225 miles, which could change in the future should there ever be an Orlando supercharger.
    The actual location that I am suggesting is only 2 miles from the I-75 interchange. Bloomingdale is another heavily traveled road, but not nearly as congested as Adamo/Brandon Blvd. Though this area could be considered to be in Riverview or Bloomingdale, the reality is that 'Brandon' is used for an area much larger than it's technical boundaries. Per Google, the southern boundary of Brandon is Bloomingdale Blvd.
    FOOD: At the SE corner is a development called the Winthrop Town Centre (http://www.winthroptowncentre.net). Food options are: Subway, Moe's Southwest Grill, Five Guys, Acropolis Greek Taverna, Green Iguana, Cappy's Pizza, The Egg & I, Starbucks, Frozen Yogurt
    Of course this could all be wrong :)
    Thanks for reading.
    Alternative: the Publix plaza on the other side of I-75 at the SW corner of Falkenburg & US301 (3863 U.S. 301 Riverview, FL 33578)
  11. jrreno
    Sarasota , Florida
    Took my test drive today AND ordered our Model S. Word is construction on the Tampa SpC starts next week! Could not get anything more specific than the malls near I4 and I75 would be a desireable place.
  12. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    Congrats on the order! Sounds like a gorgeous combination.
  13. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    I was planning a trip from NJ to St. Petersburg for early May... wonder if I'll be lucky and have a SC there by then!? :)
  14. Larry Chanin
    Sarasota, Florida
    Hi,
    Welcome to the Sunshine State!
    The permit search function doesn't let us search on the owner name so we have to guess regarding the address. So far we haven't been able to find a permit for the Supercharger. Which means either we are looking in the wrong places, or the building permit hasn't been granted yet. If we are dealing with the latter situation where they haven't broken ground, it is possible but unlikely to have an operational Supercharger station by early May.
    If you call ahead you may be able to schedule a charge at the Tampa and/or Orlando Service Centers.
    Larry
  15. wk057
    Hickory, NC, USA
    Hi Larry,
    Wishful thinking I guess!
    I had already planned to just utilize J1772 stations in the area, and if needed bug the Tampa service center for some juice. Just enough to get back to the Supercharger network really. I probably won't be driving much while I'm there anyway.
    I should probably check around if any hotels in the area would let me charge, even on 120V, since I'll be there a few days at least.
  16. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    St Pete has quite a few J1772 stations around, particularly near downtown. Many are free! What part of St Pete will you be visiting?
  17. Larry Chanin
    Sarasota, Florida
    I know of two hotels in St. Petersburg that have overnight level 2 charging.
    Loews Don CeSar Hotel
    Vinoy® Renaissance St. Petersburg Resort & Golf Club
    Below is a link to a Google map of Florida hotels with chargers. Zoom into the St. Petersburg area.
    Map of Florida Hotels with Electric Charging Stations
    Larry
  18. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    I was in the Brandon area for lunch today and took a quick run through Regency Square, the spot that Larry seems to believe will be the location for the Tampa supercharger. As far as I could tell, there are no signs of construction in that area yet, not even any areas that are taped off or otherwise blocked.
  19. TampaLiam
    TampaLiam Secret Agent
    Tampa, FL
    I think they are still working out the fine details. The spot they wanted was less than 30 feet from a through-way and a variance is needed.... or something like that...
  20. Ufrugger
    Ufrugger Member
    Trinity, FL
    Just to add an additional layer of confidence for the Regency Square location, I received an email from the property manager confirming that they are working on a lease with Tesla for the supercharger station, and looking at the design of the facilities. The manager also mentioned that Tesla is very anxious to get this location in place.
