Taptes new wireless charging pad
Discussion in 'Model 3' started by gilscales, Oct 21, 2018.
  1. substance12
    substance12 Member
    Torrance, CA
    Would you mind showing pics of the final result?
  2. daver6640
    daver6640 Member
    Fresno
    Did you order on Amazon?
  3. philaKing
    philaKing Member
    New york
    Yes I ordered on amazon.
    See some pics. It is dark so not the best. But you can see that the pad is still flush. I taped down the wireless charging disc and you can see the two pieces of black tape in the corners to keep mat secure.
    F2D4317A-86CB-401C-9B81-DB75F2810F16.jpeg D53E166B-1D1B-4F4D-8761-7C4AB3BD92A2.jpeg 75903987-8121-41F4-9FBC-419B043B4CC4.jpeg
  4. stillwaiting
    stillwaiting Member
    Bellevue
    I was doing this, however when driving the g-forces would knock the phone off its place.
  5. philaKing
    philaKing Member
    New york
    Probably depends on your case. I have the silicon Apple one which is very grippy.
  6. boriszima
    boriszima Member
    Los Angeles
    Thank you for the answer. Just ordered mine with fast charging option to get faster charge and or not use car better to charge while car is sleep, etc. Hopefully will be enough through this fairly big case.
  7. bearflag
    bearflag Member
    Orange County, CA
    For some reason the bottom of the pad was not sticking to back properly so that it would pop up a little above the black protection bar (hard to explain). Therefore I put the double side tape at the bottom of the pad so that it stuck to the back panel properly and not popped up a little.
    Maybe I was the only one that had this issue but that's what I used the double sided tape and things are working fine now. Overall I'm pleased with my Taptes wireless pads, considering the competition costs a lot more.
  8. wbhokie
    wbhokie Member
    Woodbridge, VA
    By the way, a quick follow-up. I mentioned that my Model 3 phone-tray rattled when I put weight on it, and it was especially noticeable after installing the Taptes pad and resting my phone on it. (This was not an issue with the Taptes pad itself. I didn't use the tray before due to the rattle) I was able to eliminate it completely by putting a small piece of foam on each side of the tray and pulling the tray down in place. This pretty much locks it in and it doesn't move at all and eliminates the rattle. You can see a little bit of the foam on the sides but I really don't care. (I used dark gray foam) In case anyone had a similar issue I thought I would mention it.
  9. Daniellane
    Daniellane Active Member
    Camas, Washington
    As I mentioned in a prior post...
    I ordered a clear removable/reusable double stick tape:
    https://www.amazon.com/dp/B07G9CQX83/ref=cm_sw_r_cp_api_i_HKblCb05YE7KS?&tag=tmc064-20
    I received the products but I don’t access to my Model 3/Taptes right now. It is slightly different than I expected. Inadequate description on Amazon. It is removable/reusable on just one side. The other side is a more aggressive adhesive.
    I plan to put the aggressive side on the charger so the removable side sticks to the Model 3 part.
    It is very thin.
    Looks promising...
    Pics of actual product/packaging I received:
    DA19A964-57C9-439B-8907-C87905258452.jpeg D99317ED-EA78-44F5-A03E-3AC400211D0D.jpeg D55CF4E3-95D3-4FFF-83EA-1E85BA6DACFD.jpeg 26C45D26-5840-4C7D-A1F3-3EC981D0DB85.jpeg FDD35786-8740-45A4-9A29-E2A45D3A607C.jpeg
  10. huangbong
    huangbong Member
    SF
    Great thing for us Bay Area drivers is that none of us need the battery pack upgrade. Cause if we leave our phones charging in the car while it’s off it’s gonna get broken in to in 15 minutes!
  11. swotam
    swotam Member
    Milton, Ontario
    Got mine yesterday in the Toronto area via Canada Post after ordering in early December. Quality is solid and it looks as good as the Nomad from what I can tell. It moves a tiny bit in the tray if you poke at it but certainly not enough to be noticeable when driving. I see no need to use the double-sided tape that came with it.
    My iPhone X charges perfectly and grips well on corners, etc. For $50 US it’s definitely worth it, especially compared to the Nomad at almost 3x the price.
  12. Daniellane
    Camas, Washington
    Interesting...yours came with double sided tape?
  13. lnkcrb82r3z2g4
    #433 lnkcrb82r3z2g4, Jan 6, 2019
    How soon after ordering did you receive the email asking if you prefer the matte or shiny version?
    Edit: and what are the dimensions of the 5 sticky pads? Sounds like new orders may not come with them.
  14. vipkl
    vipkl New Member
    Like others, I’d love a confirmation whether the Nomad Gen 2 coils can really do 7.5W iPhone Qi charging rate when connected to standard *5V* USB port supplying around 2 amps (such as direct to the Model 3 front USB ports).
    For example, are there *no* Qi coils on the market that can do 7.5W rate from a 5V source?
    The test results from whatthe2 are surprisingly disappointing for the Nomad. I wonder if plugging in a USB meter would show the Nomad coil pulling just ~ 1 amp from the front port? Has anyone asked Nomad to comment?
  15. Eno Deb
    Eno Deb Active Member
    SF Bay Area
    I was never asked and received the matte version. Perhaps they cancelled the shiny one?
    12 mm diameter and 3 mm thick. But my guess would be that the double-sided tape probably works just as well to eliminate the minor wiggle if it bothers you.
  16. vipkl
    vipkl New Member
    Hmm I didn't see the above bolded part from the TapTes FAQ before. Is it true that the latest iPhones on current iOS version, only use the faster 7.5W Qi charging speed for the first ~3 minutes, then drops back to the same 5W Qi rate the rest of the time? So the advertised potential advantage of the Nomad for iPhones is kinda moot?
  17. joshuaali
    joshuaali Member
    I've been following the various solutions that have been popping up - from Jeda to Nomad to Taptes. I didn't like the look of the Jeda so I only bought the Nomad and Taptes.
    A lot of misinformation has been posted, with people claiming that the two must've been made in the same factory. Clearly, they've never tried both products!
    Firstly, the Nomad:
    It has a more rubbery feel, is thicker and certainly has a bit more weight to it. Once installed, it sits flush where it's supposed to be. The downside is that due to the thickness, taller phones (such as my Pixel 3 XL with a slim case) prevent the compartment from closing. An iPhone X caused no so such problems. This was shipped from LA.
    Now, the Taptes:
    It has a more plastic feel and is slimmer and lighter. Its dimensions were also not as exact as the Nomad, which causes it to shake and rattle around. It did come with some adhesive pads but this seems like a Band-Aid solution. The upside is that even with my large phone, I could still close the compartment. This was shipped from China.
    I will probably keep the Nomad over the Taptes since it seems to be higher quality overall. And after spending $50,000 - $80,000 on the car itself, the $80 difference seems quite negligible.
  18. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    You pay for what you get. Is the Nomad worth the premium? It is for some. Not everyone, I get it.
    You did get a premium car! ;-)
    Personally, even though they are both made in China, I chose to buy from a company from my home state of California instead of Taiwan, hoping it helps keep locals employed. I can afford to, so why not.
  19. swotam
    swotam Member
    Milton, Ontario
    Yes, two strips of 3M Double-Coated Tissue Tape and the usual 5 black sticky pads. Personally I don't see the need for them, the Taptes pad only moves a tiny bit in the tray, certainly not enough to be noticeable (unless one takes corners like a maniac I suppose...).
    I never got an email asking about matte or shiny. The pad I received was matte, so I guess they've just gone with that.
  20. EVnut
    EVnut EV #5
    Davis, CA
    Same here.
