For those of you who have access to root, or the ability to query your CID, OR next time you are in for service and ask to see the Tegra CPU/Board temp for yourself.... would you please add to this thread: Your board temp (tegra) Your CPU temp (tegra) Drive time, or MCU alive time Ambient temp outside Ambient temp in cabin Your build date (optional) Your MCU date, if replaced. The speculation is that older Model S's, pre 2015, run much hotter on the tegra than newer ones. This is yet another design issue that will cause these MCUs to fail early and often, in addition to other design issues that make replacing parts within the MCU already very difficult (a soapbox for another time) Thanks!
Those who don't have root on CID, but have access to IC, run these two commands on the IC to know the cid temp: Code: /usr/local/bin/get-local-dv CenterDisplay GUI_cdProcTemp /usr/local/bin/get-local-dv CenterDisplay GUI_cdBoardTemp also for the root users, grep /var/log/syslog.* for "tempmon" to see back history of the temps going back ~1 week. run /usr/local/bin/tmon to see current values My Q1 2017 MX is always hanging around 42,35 when used, 44 is the biggest I saw, my 2014 bench is at 63,51in a cool basement. (all values are Celsius).
Today I logged: 76c CPU 63c Board MCU from a 2014 salvage 2013 build year 68F outside 68F inside Drive time was 35 mins
Garaged vehicle. Ambient 65 F. Vehicle was sleeping until 09:33 when it woke to perform a regular 12 V maintenance cycle. 2015 MCU. All energy saving modes enabled/always connected off. 2017-11-03T06:25:58.287384-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:26:59.422149-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:28:00.536507-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:29:01.673738-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:30:02.802726-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:31:03.942495-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:32:05.092479-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:33:06.241747-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:34:07.384554-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:35:08.510583-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:36:09.643320-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:37:10.798927-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:38:11.942169-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:39:13.095615-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:40:14.247105-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:41:15.382126-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:42:16.498971-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:43:17.602922-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:44:18.737243-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:45:19.829078-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:46:20.973052-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:47:22.112076-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:48:23.269987-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:49:24.415775-07:00 cid tempmon: tegra=47 board=38 2017-11-03T06:50:25.555723-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:51:26.693600-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:52:27.842665-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:53:28.981237-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:54:30.086216-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:55:31.231738-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:56:32.373916-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:57:33.504537-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:58:34.661933-07:00 cid tempmon: tegra=47 board=37 2017-11-03T06:59:35.787604-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:00:36.945837-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:01:38.135982-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:02:39.294642-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:03:40.434130-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:04:41.575788-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:05:42.714944-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:06:43.857675-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:07:44.999178-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:08:46.139054-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:09:47.290061-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:10:48.424197-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:11:49.562200-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:12:50.701941-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:13:51.846336-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:14:53.006863-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:15:54.146740-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:16:55.305032-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:17:56.436832-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:18:57.586992-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:19:58.734715-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:20:59.873944-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:22:01.011875-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:23:02.142032-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:24:03.288068-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:25:04.423000-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:26:05.545746-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:27:06.683058-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:28:07.793936-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:29:08.891242-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:30:10.042416-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:31:11.149349-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:32:12.296503-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:33:13.424672-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:34:14.564993-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:35:15.653149-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:36:16.785963-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:37:17.929250-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:38:19.072310-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:39:20.199773-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:40:21.304372-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:41:22.447364-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:42:23.587029-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:43:24.735445-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:44:25.873246-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:45:27.013035-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:46:28.160812-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:47:29.303402-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:48:30.442260-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:49:31.573354-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:50:32.654056-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:51:33.793678-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:52:34.933496-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:53:36.087596-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:54:37.242388-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:55:38.383299-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:56:39.522150-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:57:40.661968-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:58:41.792149-07:00 cid tempmon: tegra=47 board=37 2017-11-03T07:59:42.894508-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:00:44.043261-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:01:45.203765-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:02:46.349402-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:03:47.487548-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:04:48.622223-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:05:49.755344-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:06:50.895440-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:07:52.035396-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:08:53.174123-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:09:54.289434-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:10:55.428170-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:11:56.576494-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:12:57.719367-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:13:58.818955-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:14:59.972474-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:16:01.112119-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:17:02.253566-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:18:03.361277-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:19:04.487597-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:20:05.615896-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:21:06.755648-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:22:07.894932-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:23:09.038626-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:24:10.175626-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:25:11.312237-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:26:12.464353-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:27:13.618404-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:28:14.768287-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:29:15.903013-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:30:17.055564-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:31:18.192937-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:32:19.333091-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:33:20.476083-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:34:21.613956-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:35:22.741604-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:36:23.873538-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:37:25.012756-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:38:26.155957-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:39:27.305262-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:40:28.461562-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:41:29.611091-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:42:30.694997-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:43:31.779602-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:44:32.922253-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:45:34.072290-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:46:35.215318-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:47:36.364395-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:48:37.502312-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:49:38.636461-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:50:39.746211-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:51:40.889204-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:52:42.014268-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:53:43.153627-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:54:44.295441-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:55:45.433194-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:56:46.579463-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:57:47.703747-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:58:48.845271-07:00 cid tempmon: tegra=47 board=37 2017-11-03T08:59:49.985698-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:00:51.097367-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:01:52.251103-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:02:53.392947-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:03:54.533653-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:04:55.640956-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:05:56.775217-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:06:57.935158-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:07:59.086463-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:09:00.234329-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:10:01.386879-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:11:02.522581-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:12:03.654222-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:13:04.803947-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:14:05.971219-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:15:07.055843-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:16:08.194454-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:17:09.296133-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:18:10.426547-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:19:11.562257-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:20:12.685477-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:21:13.822181-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:22:14.966479-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:23:16.105988-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:24:17.262612-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:25:18.410478-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:26:19.536615-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:27:20.654268-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:28:21.793614-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:29:22.919868-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:30:24.074033-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:31:25.216696-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:32:26.374168-07:00 cid tempmon: tegra=47 board=37 2017-11-03T09:33:29.218109-07:00 cid tempmon: tegra=48 board=38 2017-11-03T09:34:30.411991-07:00 cid tempmon: tegra=48 board=38 2017-11-03T09:35:31.581899-07:00 cid tempmon: tegra=49 board=39 2017-11-03T09:36:32.762603-07:00 cid tempmon: tegra=49 board=39 2017-11-03T09:37:33.960092-07:00 cid tempmon: tegra=50 board=40 2017-11-03T09:38:35.140435-07:00 cid tempmon: tegra=50 board=41 2017-11-03T09:39:36.310763-07:00 cid tempmon: tegra=51 board=41 2017-11-03T09:40:37.463785-07:00 cid tempmon: tegra=51 board=42 2017-11-03T09:41:38.631576-07:00 cid tempmon: tegra=52 board=42 2017-11-03T09:42:39.840003-07:00 cid tempmon: tegra=52 board=42 2017-11-03T09:43:41.002225-07:00 cid tempmon: tegra=53 board=43 2017-11-03T09:44:42.170951-07:00 cid tempmon: tegra=53 board=43 2017-11-03T09:45:43.333370-07:00 cid tempmon: tegra=53 board=43 2017-11-03T09:46:44.505027-07:00 cid tempmon: tegra=54 board=44 2017-11-03T09:47:45.701568-07:00 cid tempmon: tegra=54 board=44 2017-11-03T09:48:46.857932-07:00 cid tempmon: tegra=54 board=44 2017-11-03T09:49:48.038436-07:00 cid tempmon: tegra=55 board=45 2017-11-03T09:50:49.213401-07:00 cid tempmon: tegra=55 board=45 2017-11-03T09:51:50.375547-07:00 cid tempmon: tegra=55 board=45 2017-11-03T09:52:51.552201-07:00 cid tempmon: tegra=55 board=45 2017-11-03T09:53:52.732622-07:00 cid tempmon: tegra=55 board=45 2017-11-03T09:54:53.909773-07:00 cid tempmon: tegra=56 board=46 2017-11-03T09:55:55.106369-07:00 cid tempmon: tegra=56 board=46 2017-11-03T09:56:56.283440-07:00 cid tempmon: tegra=56 board=46 2017-11-03T09:57:57.448803-07:00 cid tempmon: tegra=56 board=46 2017-11-03T09:58:58.609949-07:00 cid tempmon: tegra=56 board=46 2017-11-03T09:59:59.789173-07:00 cid tempmon: tegra=56 board=46 2017-11-03T10:01:00.979301-07:00 cid tempmon: tegra=56 board=46 2017-11-03T10:02:02.141247-07:00 cid tempmon: tegra=57 board=46 2017-11-03T10:03:03.300504-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:04:04.478561-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:05:05.642273-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:06:06.807265-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:07:07.990247-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:08:09.150279-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:09:10.304460-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:10:11.469912-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:11:12.622328-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:12:13.807190-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:13:14.992093-07:00 cid tempmon: tegra=57 board=47 2017-11-03T10:14:16.176960-07:00 cid tempmon: tegra=58 board=47 2017-11-03T10:15:17.335708-07:00 cid tempmon: tegra=58 board=47 2017-11-03T10:16:18.503570-07:00 cid tempmon: tegra=58 board=47 2017-11-03T10:17:19.662753-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:18:20.854311-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:19:22.033353-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:20:23.260814-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:21:24.433534-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:22:25.593651-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:23:26.794235-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:24:27.981997-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:25:29.152932-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:26:30.327930-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:27:31.480825-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:28:32.665708-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:29:33.804359-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:30:34.991477-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:31:36.155892-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:32:37.295298-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:33:38.465091-07:00 cid tempmon: tegra=58 board=48 2017-11-03T10:34:39.624923-07:00 cid tempmon: tegra=58 board=48
Interesting, seems like 2017 cars operate even LOWER than 2015s, there must be a mid range as well...
So I guess here's the hard data form mine. at 11:50 I had a bit of a drive around and you can see corresponding rise in temperatures. Code: 2017-11-03T11:36:28.228374-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:37:29.391937-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:38:30.605376-07:00 cid tempmon: tegra=38 board=32 2017-11-03T11:39:31.769004-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:40:32.947286-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:41:34.117030-07:00 cid tempmon: tegra=38 board=32 2017-11-03T11:42:35.277933-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:43:36.450003-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:44:37.607047-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:45:38.790909-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:46:39.954750-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:47:41.121427-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:48:42.221384-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:49:43.378283-07:00 cid tempmon: tegra=37 board=32 2017-11-03T11:50:44.609819-07:00 cid tempmon: tegra=38 board=32 2017-11-03T11:51:45.968905-07:00 cid tempmon: tegra=38 board=33 2017-11-03T11:52:47.327960-07:00 cid tempmon: tegra=39 board=33 2017-11-03T11:53:48.677343-07:00 cid tempmon: tegra=39 board=34 2017-11-03T11:54:49.925208-07:00 cid tempmon: tegra=40 board=34 2017-11-03T11:55:51.197461-07:00 cid tempmon: tegra=40 board=35 2017-11-03T11:56:52.548673-07:00 cid tempmon: tegra=40 board=35 2017-11-03T11:57:53.779599-07:00 cid tempmon: tegra=41 board=36 2017-11-03T11:58:55.034766-07:00 cid tempmon: tegra=41 board=36 2017-11-03T11:59:56.247561-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:00:57.472676-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:01:58.646560-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:02:59.834096-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:04:01.030292-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:05:02.209724-07:00 cid tempmon: tegra=42 board=37 2017-11-03T12:06:03.417257-07:00 cid tempmon: tegra=42 board=37 2017-11-03T12:07:04.606037-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:08:05.785602-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:09:06.973846-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:10:08.163341-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:11:09.342768-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:12:10.543216-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:13:11.746245-07:00 cid tempmon: tegra=43 board=38 2017-11-03T12:14:12.990513-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:15:14.245934-07:00 cid tempmon: tegra=44 board=39 2017-11-03T12:16:15.492381-07:00 cid tempmon: tegra=44 board=39 2017-11-03T12:17:16.730882-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:18:18.003695-07:00 cid tempmon: tegra=44 board=39 2017-11-03T12:19:19.259262-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:20:20.503498-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:21:21.804258-07:00 cid tempmon: tegra=44 board=39 2017-11-03T12:22:23.059789-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:23:24.270081-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:24:25.458474-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:25:26.640700-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:26:27.832844-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:27:29.066923-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:28:30.260367-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:29:31.456588-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:30:32.670771-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:31:33.981944-07:00 cid tempmon: tegra=42 board=39 2017-11-03T12:32:35.294905-07:00 cid tempmon: tegra=41 board=38 2017-11-03T12:33:36.578447-07:00 cid tempmon: tegra=40 board=37 2017-11-03T12:34:37.883993-07:00 cid tempmon: tegra=40 board=37 2017-11-03T12:35:39.091120-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:36:40.271418-07:00 cid tempmon: tegra=41 board=37 2017-11-03T12:37:41.459794-07:00 cid tempmon: tegra=42 board=37 2017-11-03T12:38:42.657409-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:39:43.844600-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:40:45.050452-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:41:46.246409-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:42:47.440419-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:43:48.618601-07:00 cid tempmon: tegra=43 board=38 2017-11-03T12:44:49.833099-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:45:51.033457-07:00 cid tempmon: tegra=42 board=38 2017-11-03T12:46:52.217797-07:00 cid tempmon: tegra=43 board=38 2017-11-03T12:47:53.402129-07:00 cid tempmon: tegra=43 board=39 2017-11-03T12:48:54.616675-07:00 cid tempmon: tegra=43 board=39
Do we actually know what the specifications are as far as operating temperature for the components on the Tegra board? I agree that 60 C seems hot, but could it be that Tesla is using automotive grade electronics that are designed to withstand these temps?
Ok. And do we have any idea what changed to enable the Tegra to run cooler? A better heatsink? A bigger fan?
Its a video card at its core so.... probably both or either? I'm be curious to the hardware differences of @verygreen vs me for example.
BTW this is my bench, situated in a cool basement (~68F, 20C), made sometime in 2014: Code: Oct 30 17:05:08 cid tempmon: tegra=30 board=22 Oct 30 17:06:09 cid tempmon: tegra=33 board=25 Oct 30 17:07:13 cid tempmon: tegra=35 board=27 Oct 30 17:08:14 cid tempmon: tegra=38 board=29 Oct 30 17:09:15 cid tempmon: tegra=40 board=31 Oct 30 17:10:16 cid tempmon: tegra=42 board=33 Oct 30 17:11:17 cid tempmon: tegra=44 board=34 Oct 30 17:12:19 cid tempmon: tegra=46 board=36 Oct 30 17:14:21 cid tempmon: tegra=49 board=38 Oct 30 17:15:22 cid tempmon: tegra=50 board=39 Oct 30 17:16:23 cid tempmon: tegra=51 board=40 Oct 30 17:17:24 cid tempmon: tegra=52 board=41 Oct 30 17:18:25 cid tempmon: tegra=53 board=42 Oct 30 17:19:26 cid tempmon: tegra=54 board=43 Oct 30 17:20:27 cid tempmon: tegra=55 board=43 Oct 30 17:21:29 cid tempmon: tegra=56 board=44 Oct 30 17:22:30 cid tempmon: tegra=56 board=45 Oct 30 17:23:31 cid tempmon: tegra=57 board=45 Oct 30 17:24:32 cid tempmon: tegra=58 board=46 Oct 30 17:25:33 cid tempmon: tegra=58 board=46 Oct 30 17:26:34 cid tempmon: tegra=59 board=47 Oct 30 17:27:35 cid tempmon: tegra=59 board=47 Oct 30 17:28:36 cid tempmon: tegra=59 board=47 Oct 30 17:29:37 cid tempmon: tegra=60 board=48 Oct 30 17:30:39 cid tempmon: tegra=60 board=48 Oct 30 17:31:40 cid tempmon: tegra=60 board=48 Oct 30 17:32:41 cid tempmon: tegra=61 board=48 Oct 30 17:33:42 cid tempmon: tegra=61 board=49 Oct 30 17:34:43 cid tempmon: tegra=61 board=49 Oct 30 17:35:44 cid tempmon: tegra=61 board=49 Oct 30 17:36:45 cid tempmon: tegra=61 board=49 Oct 30 17:37:46 cid tempmon: tegra=62 board=49 Oct 30 17:38:47 cid tempmon: tegra=62 board=49 Oct 30 17:39:48 cid tempmon: tegra=62 board=50 Oct 30 17:40:50 cid tempmon: tegra=62 board=50 Oct 30 17:41:51 cid tempmon: tegra=62 board=50 Oct 30 17:42:52 cid tempmon: tegra=62 board=50 Oct 30 17:43:53 cid tempmon: tegra=63 board=50 Oct 30 17:44:54 cid tempmon: tegra=63 board=50 Oct 30 17:45:55 cid tempmon: tegra=63 board=50 Oct 30 17:46:56 cid tempmon: tegra=63 board=50 Oct 30 17:47:57 cid tempmon: tegra=63 board=50 Oct 30 17:48:58 cid tempmon: tegra=63 board=50 Oct 30 17:50:00 cid tempmon: tegra=63 board=50 Oct 30 17:51:01 cid tempmon: tegra=63 board=50 Oct 30 17:52:02 cid tempmon: tegra=63 board=50 Oct 30 17:53:03 cid tempmon: tegra=63 board=51 Oct 30 17:54:04 cid tempmon: tegra=63 board=51 Oct 30 17:55:05 cid tempmon: tegra=63 board=51 Oct 30 17:56:06 cid tempmon: tegra=63 board=51 Oct 30 17:57:07 cid tempmon: tegra=63 board=51 Oct 30 17:58:08 cid tempmon: tegra=63 board=51 Oct 30 17:59:09 cid tempmon: tegra=63 board=51 Oct 30 18:00:11 cid tempmon: tegra=63 board=51 Oct 30 18:01:12 cid tempmon: tegra=63 board=51 Oct 30 18:02:13 cid tempmon: tegra=64 board=51 Oct 30 18:03:14 cid tempmon: tegra=64 board=51 Oct 30 18:04:15 cid tempmon: tegra=64 board=51 Oct 30 18:05:16 cid tempmon: tegra=64 board=51 Oct 30 18:06:17 cid tempmon: tegra=64 board=51 Oct 30 18:07:18 cid tempmon: tegra=63 board=51 Oct 30 18:08:19 cid tempmon: tegra=64 board=51 afterwards it stays pretty much there. Since I am absolutely not taking my car apart (at this point, anyway), I cannot really compare my bench to in-car cid. The other difference is my bench is on 7.1 firmware, since I did not see a compelling reason to upgrade it any further
From eMMC manufacturer specifications its operating temperature range is: -40℃ ~ 85℃. But it is also known that all silicon chips suffer from elevated temperatures and it definitely shortens chip lifespan. Thus operating very close to the upper bound of specification is a death caller for flash. Above 85C it will simply die very fast. My bench Tegra's heatsink is so hot that I barely can keep my fingers on it. I've never seen a CPU with proper heatsink running that hot. Also fan on my CID's Tegra never turns on. It was me who first noticed that and later Demundus started to monitor his Tegra being concerned that heatsink may have been improperly installed. If it is indeed a physical design failure that prevents fan from turning on then it is very bad. Heatsink is wrapped into air duct which effectively blocks natural airflow (via convection) through the heatsink when fan is not running. To remediate this issue I would suggest either of two things: - Remove air duct around heatsink (and fan casing) since it is useless and makes things worse - Give proper power to the fan so it will be constantly running pulling air through the heatsink.
Ok, I have a September 2013 Model S and like to chime in, but how do I get access? I work as a daily Linux sysadmin, so the CLI is no problem. But running with v8.1 is there a easy way to get in? Any links with information on how to achieve this?
I find it difficult to believe that for 3 years Tesla designed the cars with a design defect that prevented the MCU fans from operating correctly. Having said that, I rarely hear the MCU fans spin up in mine. I suspect that Tesla could change this via firmware to run the fans more often.
Could be they had other fish to fry, since they aren't failing that often unlike say the door handles, so maybe they didn't even worry about it. Another good example, i've had my car for roughly 10 months now, i'm on my 3rd charge port
I could believe that if the MCU stayed on revision A for 3 years. But when I had mine swapped in late 2015 I had a revision M put in. So clearly they were actively making design decisions that affected the MCU.
Funny enough, I removed the duct when I re-installed because I questioned its efficacy, design wise it made no sense. Is there an always on setting in the OS somewhere I can set to read only for the fan?
If you do not have root, you need to get onto the in-car network ( Successful connection on the Model S internal Ethernet network ) You won't get the history, but you can impersonate IC and see the current CID temps via GUI_cdProcTemp and GUI_cdBoardTemp variables
