Temperature Drop Tire Issues
Discussion in 'Hong Kong' started by MrGrumpy, Mar 10, 2016.
Tags:
  1. MrGrumpy
    MrGrumpy Member
    Hong Kong
    #1 MrGrumpy, Mar 10, 2016
    There seems to be tire issues with my Model S on 21" whenever the air temperature (weather) drops rapidly:
    In January the day when it dropped to 3 degrees, TPMS alerted low pressure (~1.7 bar) on my front left tire. Checked it out at a tire shop and said the sealing around the monitor inside the tire wasn't fitted very well and when it gets cold and shrinks a bit, air goes out.
    Tonight when I drove TPMS alerted me for the rear right tire @2.4 bar. Haven't checked it out it yet but wondering if any of you have encountered similar issues.
    And may I ask what pressure does are your 21" tires running on?
    Thanks!
  2. jerry33
    Texas
    Basically, when it gets cold inflate your tires to spec first thing in the morning before you drive more than 2 km slowly. If it warms up later in the day or the next day, don't worry about it they'll be fine.
  3. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Wow. My TPMS doesn't alert me to anything until the tire is essentially out of air. Fortunately, I have been the one bleeding the air off. I had one instance where I picked up a screw and pressure dropped from 42 to 32, which I view as very significant. The only reason I knew was that I had the display up on the IP and happened to notice it. I am sure I would have been flat within a few hours after getting home. My Acura would notify me if it lost approx 10-15% of pressure (3-5 PSI). The next time I go in, I will have a chat with service.
  4. AppleFan
    AppleFan Member
    Hong Kong
    It's "normal" as it's just physics. At a given volume (the tire), when temperature falls, pressure falls.
    As for the correct pressure, it's written on the label near the driver door. (Open the door, and look down towards the car body.) If I remember correctly, 21" should be 42 psi, but I think that was for the older Continental tires -- not sure if the newer Michelin tires need a different psi.
    Hope this helps.
  5. jerry33
    Texas
    That's the vehicle placard pressure. It's a staring place, not necessarily the "correct" pressure. Any pressure recommendation is based on a set of assumptions, change any one of the assumptions and the pressure needs to be adjusted. Generally for on-road use the vehicle placard pressure is the pressure you never want to go below.
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    My late 2013 S does not have the individual tire pressure display that the newer cars have, but a year ago it did alert me to a tire that was down by about 5 psi compared to the other three tires.
