Temperature randomly rising.
Anyone run into this. My car sitting there since I parked it this morning. It’s in NJ and it’s 40 degrees outside. I was checking my referral count and saw that my car was going crazy and was at 100+ degrees. I turned on cabin cooling but grabbed a screen shot. Freaked out now...
So, which is it? Is the factory glass coating excellent at filtering heat or is it a green house? The answer seems to change depending on what you are asking....
both. because the front, back and sides are untreated like a normal car. and like a normal car, it can get damn hot if you don't crack a window. If untreated, the top glass would create even hotter conditions than a typical car.
