benji4
Roadster 2.5 #0476
Good point! We need the acceleration to stay where it is -- so just supporting quick charging will be fine with the 1000 pound pack!
I've read through this thread but had a question. It looks like the TEPCO/CHAdeMO plug will be different than whatever the level 3 J1772 standard will be if I understand this correctly. Is this going to turn into a VHS/Betamax or HD-DVD/Bluray kind of fight in terms of standards? It wasn't clear to me from the presentation link but is their proposed level 3 J1772 plug going to be the same as the current J1772 lever 2 plug? For example, will you be able to pull up to a charging station in the future in your EV with a J1772 plug and charge either at level 2 or 3 from the same plug? Thanks.If SAE wants to get its system out there, they'd better be quick. If you are going to have J1772 for level 2 charging, then the J1772 level 3 DC spec is much better than having a completely separate socket. See here.
There needs to be one established connection for all levels.
The 'current' J1772 plug/socket isn't adequate for DC Level 3 quick charge.
So, two different plugs seems like it may be what they have in mind.
Too many standards is definately not good. I guess you could use adapters, but why?
I think that is oversimplified.
Quick/Fast charge tends to need heavier gauge wire, bigger pins, and better insulation.
(In other words, more expensive and bulky.)
Different parts of the world have different current types commonly available so it isn't as easy as "one size fits all".
But given all that, there are still regional "turf wars" over who gets to "own the standard" even when it could be shared with other areas. It is good that J1772 at least handles level 1 & level 2, and is common between Leaf, Volt, and other upcoming vehicles like plug in Prius and probably Model S.
CHAdeMO is a standard that could be used, but I think even Nissan and Mitsubishi view it as tentative since it was based on an emerging standard from the Japanese market and hasn't been accepted yet in other parts of the world. Tesla might have good reasons both political, & technical that would prevent them from fully embracing CHAdeMO just now.
I think a sensible approach (as things stand) might be for Model S to have the J1772 Level 2/3 combined socket on one side and the CHAdeMO socket on the other side for North American and Japanese markets, and the Mennekes and CHAdeMO sockets for European markets. I'm expecting Nissan to roll out CHAdeMO in various locations here too as the Leaf gets established.
The Level 3 J1772 is an extension of the Level 2 version. It has the two extra DC pins...
...The Yazaki plug that was built to the SAE J1772 plug standard successfully completed certification at UL. It is only certified to 30A although the standard is written to 80A...
I think some of it boils down to CHAdeMO is available now, but high speed (Level 3) J1772 isn't quite ready yet....Work continues on specifications for higher-voltage, DC Fast Charge charging,[4] which has been referred to as level 3 charging. As of February 2010, the SAE J1772 committee is designing a DC connector based on the SAE J1772 AC connector with additional DC and ground pins, to then evaluate against other designs including the JARI/TEPCO connector used by the CHAdeMO DC fast charge protocol.[6] There are indications SAE is also investigating a third level of AC charging...
It seems even with the lower power AC J1772 ("Level 2+") most plugs & sockets made so far aren't even rated for full current.
http://en.wikipedia.org/wiki/SAE_J1772
http://www.blinknetwork.com/media/kit/Blink DC Fast Charger.pdf...The DC Fast Charge stations are 208/380/400/480/575 VAC 3-Phase input and can output between 200 VDC - 450 VDC, 200 amps max. The connector is a Yazaki-CHAdeMO, 120A rated. Here are the Blink Specs. Here is an intoduction to the CHAdeMO standard...
Whats the hell do you want an expensive DC Fast Charge when 3-phase AC is already available. Just plug in the sleek Mennekes adapter without heavy hi-current cord, just using simple cord. with charging power up to 44kW. Only above 100kW DC-Charging make sense...The DC Fast Charge stations are 208/380/400/480/575 VAC 3-Phase input and can output between 200 VDC - 450 VDC, 200 amps max. The connector is a Yazaki-CHAdeMO, 120A rated. Here are the Blink Specs. Here is an intoduction to the CHAdeMO standard...
In a recent video, the communications manager for Tesla indicates that 'Fast Charging' will be an innovation on the model S. Although early in the interview she says she can't talk about it see time stamp at 4:20
