IMHO we discussed some of this UI positioning when 7.0 first hit the streets in the primary 7.0 thread, as a number of us have issues with comfortable seat & steering wheel positions that then block a significant amount of the upper part of the IC as well as both upper corners. With 7.0 and Autopilot, that means for me, I can't see 75% of even the speed digits I'm traveling at, let alone the Autopilot indicators or ANY of the emergency/indicator icons across the top of the IC without acting like a goose to move my head to see under the wheel. I don't think it's important here to get hung up on Tech Pkg/AutoPilot/or-not, but rather, that the most important indicators to safely drive a Tesla need to be in the prime space most drivers can always see. As it is, IMHO, it's not.
I agree with HankLloydWright that the Tesla developers are likely using workstations with simulated ICs that don't have indicators where the increasingly hidden areas are for some drivers. The IC is large, which is great, but I can't believe it's 100% visible to all drivers as the present UI would seem to suggest. THAT needs to be a prime consideration in Tesla's UI design, and seems to have been deprioritized with 7.0.
As it is, I have recently moved my steering wheel much higher than I prefer. It's not optimum comfort-wise, and will be a big problem on longer drives. Trading off my comfort for safety, I can now see enough of the IC and the speed I'm traveling at to know what it is, along with the two Autopilot icons on either side. Even so, none of the indicator icons across the top of the screen are visible without doing occasional neck exercises to see what may be hidden, meaning I will likely miss an emergency indicator if there is no corresponding beep or message at the bottom center of the display.
To me, Tesla can resolve a great deal of this by moving up the whole Autopilot graphic for those that have it, and moving speed down underneath that graphic with the most imperative indicators to the left and right. Squeeze a little space from behind my toy MS to help the situation. I'd rather forego some of the detail in the far distance ahead of me and let that be hidden by the steering wheel if I had to. Keep emergency messages at the very bottom center below everything as they are, and move up things like temp and even the gear we're in if need be -- which don't need to be as obvious or that change (as often) while driving. If part of the left and right optional apps (including Nav on the left) needs to be scaled down to fit the emergency icons and key indicators, so be it... I'd rather have to seek out the corner detail of the Nav and Trip apps upon occasion behind the wheel, than the basics I need to safely drive my Tesla like I'm living with now.
