Tesla 13a charger, is it waterproof?
abbo100
New Member
Nov 23, 2020
2
0
North West
Afternoon folks,
Just a quick question regarding the Tesla 13a charging cable.
I usually do all my charging at work so have never had any need for a home charging solution. However as I’m going to on holiday for a couple of weeks with no access to the works charger I need an option for home.
My problem is that I don’t have a garage, or anywhere that’s accessible undercover, other than passing the cable through a downstairs window.
I do however have an outdoor weatherproof socket next to my drive that is ideally placed, looking at the Tesla charger it doesn’t look to be weatherproof so would rather get confirmation before attempting to use it and tripping my electricity supply.
Can anyone confirm if these are designed to be used in environments where they will get wet?
DSolie
Pew Pew
Jul 2, 2020
332
692
Olympia, WA
It's not water proof, it is water resistant. It can get wet. What I would do is plug it into your exterior outlet and then use a garbage bag to loosely cover the UMC. I assume this is a 15-Amp exterior outlet, so there shouldn't be too much heat transfer. You can also use an extension cord (a good one) to get the UMC under your car, then plug it in. Put the UMC on top of the tire or something.
abbo100
New Member
Nov 23, 2020
2
0
North West
That’s great, thanks for the info, I’ll get something sorted out.
