Thanks, good to know!Also, keep in mind the connector knows which tail it attaches to, and sets max current accordingly. So no matter what adapter you put on with the 5-15 original tail, the max current is 12A.
I'd highly recommend the 5-20 adapter as well. On two occasions now we've rolled into national park campsites where the 14-50 receptacle is out of service, and that household outlet becomes the lifeline. Neither are great, but there's a significant improvement to using the 5-20 over the 5-15, particularly if leaving electrical loads on overnight (climate, sentry, etc).for the most part you will only likely use the 5-15 and 14-50 adapters.
Absolutely. 14-50 and 5-20 are my camping standard set. The 5-20 is used the most, and is much faster than the 5-15 (more than 33% faster because it takes a relatively fixed amount of power to run the car while charging regardless of charging speed).I'd highly recommend the 5-20 adapter as well. On two occasions now we've rolled into national park campsites where the 14-50 receptacle is out of service, and that household outlet becomes the lifeline. Neither are great, but there's a significant improvement to using the 5-20 over the 5-15, particularly if leaving electrical loads on overnight (climate, sentry, etc).
Those "household three prong outlets" may actually be 5-20 outlets. (If they have the horizontal opening for the blade.)When would 5-20 be used at a campsite? We have a 30A, 50A and two household three prong outlets at the site.
Is it okay to plug things into them that fit that pattern? We plugged the Prius Prime into it.Those "household three prong outlets" may actually be 5-20 outlets. (If they have the horizontal opening for the blade.)
Yep, as long as the plug fits without forcing anything you are fine. (A 5-20 outlet is backwards compatible with 5-15 plugs, it can take either.)Is it okay to plug things into them that fit that pattern? We plugged the Prius Prime into it.
I take it there were no issues with the Prius ? Best peace of mind of any vehicle.We made it to the campground. We brought the MYP and our Prius Prime. The campground has a 50A, 30A, and two regular household outlets (they told me they didn't have them, but they are here).
I bought the Tesla 14-50 adapter at the service center. I took it out of the box for the first time today. I also got a 15A to 30A adapter from Harbor Freight for the Prius, which we didn't need since they have two household outlets.
Anyway, I have no idea what is going on with the other end of the Tesla 14-50 adapter. It doesn't seem to fit anything! I plugged the Tesla charging cord into the 15 to 30A adapter and plugged that into the 30A outlet. The car says that it is charging at 12A and it will take 11 hours and 30 minutes to go from 234 miles to 286 (100%).
I supercharged before getting here, so we have enough charge to get back to the Supercharger, which is 30 miles away. This is not an emergency, thankfully, but we had planned on going to WV and using their 50A, and there are no Superchargers. I'm happy to find out here that I have a problem instead of the middle of nowhere!
I left the car in camp mode since we have a 12V cooler in the sub trunk. We bought the Alpicool K25, which fits perfectly in the sub trunk. I have the sub trunk opened a few inches to vent. It worked great going from PA to OH. We plugged it into the room at the Airbnb we got (to have somewhere to go besides the back of the car!). It's been working out so far.
I'm getting 0 miles per hour.
Does this charge rate seem correct at 30A??
Any idea what is on the other end of the Tesla 14-50 adapter?
Pictures attached!! Thanks all!!
It was able to charge. It gets around 25 miles on electric. In traffic, I get 70 mpg without having a charge.I take it there were no issues with the Prius ? Best peace of mind of any vehicle.
We were able to get a 15A to 30A from Harbor Freight. That's what I originally used when I at first couldn't plug in the 14-50. How is the TT30 different? I was going to order the TT30, but EVSE were out of stock.These are the four adapters you need for your mobile charge cord. From left to right. And their max charge currents and volts.
14-50. From tesla. 32 amp 240 v.
5-15. From Tesla. 12 amp 120 v
5-20. From Tesla. 16 amp 120 V
TT30. From EVSE adapters. 24 amp 120 v.
12000 ish kilometres camping across Canada experience. Yep, been there.
The TT30 tells the charge cable (EVSE) that it is a 30 amp outlet and that 24 amps can be drawn. If you just use a hardware store converter the EVSE just sees 120 volts and assumes only 15 amps is available and limits to 12 amps. Using the TT30 adapter from EVSE adapters doubles you charging speed.We were able to get a 15A to 30A from Harbor Freight. That's what I originally used when I at first couldn't plug in the 14-50. How is the TT30 different? I was going to order the TT30, but EVSE were out of stock.
How do you like your camper? Which one is it? We looked at the mini max, but it was really small.
We love it and we travel a lot in it. It is a T@B 400 non Boondock. (Boondock is too high).We were able to get a 15A to 30A from Harbor Freight. That's what I originally used when I at first couldn't plug in the 14-50. How is the TT30 different? I was going to order the TT30, but EVSE were out of stock.
What is your driving range between stops with the tear drop camper? My wife and I have considered getting one, but are concerned about "real world" range between stops.
Yes! That is exactly what happened. I was charging at 0 to 1 mph! Good point. When the 30TT is back in stock, I will get one. Would tbT be 2 mph though? Here is what we were getting at 12A.The TT30 tells the charge cable (EVSE) that it is a 30 amp outlet and that 24 amps can be drawn. If you just use a hardware store converter the EVSE just sees 120 volts and assumes only 15 amps is available and limits to 12 amps. Using the TT30 adapter from EVSE adapters doubles you charging speed.
In addition to all of the great info @Webeevdrivers has posted, I'll throw in a caution that you still have to keep track of loads when using adapters of any kind.The TT30 tells the charge cable (EVSE) that it is a 30 amp outlet and that 24 amps can be drawn. If you just use a hardware store converter the EVSE just sees 120 volts and assumes only 15 amps is available and limits to 12 amps. Using the TT30 adapter from EVSE adapters doubles you charging speed.
It would be more.Would tbT be 2 mph though? Here is what we were getting at 12A.
Not really sure but I’ll guess at 220 ish kilometres. The superchargers are closer than that so it never comes up.What is your driving range between stops with the tear drop camper? My wife and I have considered getting one, but are concerned about "real world" range between stops.
Keith
