Tesla adding front motor to inventory RWD to make AWD?
Discussion in 'Model 3: Ordering, Production, Delivery' started by SoCalGuy, Aug 3, 2018.
  1. SoCalGuy
    SoCalGuy Active Member
    So Cal & New York, NY
    I was wondering if, given all M3s are designed to have a front motor and all the stockpiled RWD Model 3s Tesla had prior to July 1, they would be retrofitting some of the less popular color cars (eg silver, blue) with a front motor to the extent there is more demand for those colors in AWD.
    For example, if Tesla had a couple hundred silver RWD waiting for an order to match, would they instead add a front motor to those cars if they had pending silver AWD non-P orders waiting? This would save them the trouble of the paint shop switching to batch produce silver and blue cars and also clear out some aging RWD inventory.
    Thoughts?
    • Disagree x 2
  2. SD_Engnr
    SD_Engnr Active Member
    San Diego
    It's a possibility, but I imagine there's additional wiring, suspension changes, and then a VIN tag change, too.
  3. MXWing
    MXWing Well-Known Member
    Tesla has the entire world that wants the M3.
    We can’t be so American centric to not realize that.
    There’s no sense or reason to do any retrofits or upgrades when you are shooting for 10K a week volume.
    When you can build a 10 cars for every one car you try to retrofit it won’t make sense to do so from an efficiency and cost standpoint.
    Can be done, ought to be done are two different things.
    • Funny x 2
  4. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Not likely at all as that would mean replacing the battery and front suspension at a minimum, and probably the SuperBottle as well.
    Not to mention that I don't think there are actually stockpiled "inventory" Model 3s. They are just having problems ramping up logistics and delivery as fast as they did production.
    • Disagree x 1
  5. SoCalGuy
    SuperBottle?
  6. MP3Mike
    Oregon
    #6 MP3Mike, Aug 3, 2018
    Yeah, that is what Tesla calls the heart of the cooling system. It even has a SuperBottle logo on it. It would likely need changes for cooling plumbing for the front motor. (Possibly even an additional pump.)
    There is some information about it here: Tesla’s Model 3 Is Elon Musk’s Hell
    You can see it in this video: (Starts around 55 seconds in.)
    I tried to do a capture and edit the picture so you could see it better: (But it still sucks.)
  7. xdriv3
    xdriv3 Member
    NY
    They keep filling RWD orders. The demand is also there. No way they'd retrofit already manufactured cars.
    You have people who order/config RWD cars in recent weeks and getting order status updates/matches in a few days after that.
    They also keep registering RWD VINs as well.
    Perhaps though should stop RWD production and focus on AWD to alleviate the pent up demand.
  8. ebmcs03
    ebmcs03 Active Member
    So Cal
    I don’t think there’s many stock piled anymore there’s enough ppl who ordered on 6/27
  9. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    It wouldn't be worth the effort and cost. Doing so would take thousands in parts and labor while simultaneously making a used car more expensive. It's good for Tesla to have a used car pool with a range of prices.
  10. rdlink
    rdlink Member
    Colorado
    The RWD has a differently rated rear motor, also.
  11. SoCalGuy
    True. But consensus seems to be that the rear motor output is software limited
  12. MP3Mike
    Oregon
    Interesting but you will notice that the 2018 RWD has the same 211kW rear motor:
  13. rdlink
    rdlink Member
    Colorado
    Yeah, I messed up and pulled the 2017 RWD into the comparison sheet. Didn't notice that.
  14. rdlink
    rdlink Member
    Colorado
    I'd like to know where that consensus is. I haven't seen anyone provide any proof other than their gut/wishes. Elon himself said that rear motors for the Performance models are "lot sorted for highest sigma output & get double the burn in." That seems completely hardware/physical to me.
  15. shanejackson
    shanejackson Member
    AWD and P motors are the exact same! The only difference is the inverter on the rear. The P uses the same inverter as the LR RWD. The AWD uses a lower output inverter.
  16. Knightshade
    Knightshade Active Member
    NC
    Lot sort makes no sense if they’re physically different parts
    Lot sort BY DEFINITION is sorting the SAME physical parts.
    Musk said Drive units are sorted-so again that would make no sense
    The inverter is part of the drive unit
    The fact the AWD and P have the same VIN letter for drive unit ought make the fact it’s identical hardware even more clear
    It’s certainly possible an awd teardown will contradict what the info we have tells us- but right now it’s telling us same hardware
  17. rdlink
    rdlink Member
    Colorado
    I'm willing to concede that it may be the same exact hardware, except for the sorting and double burn-in. But that is the opposite of a software difference. You can't overcome a manufacturing quality difference with a software tweak.
  18. Knightshade
    NC
    There’s no evidence of a quality difference
    Unless their tolkerances are garbage the best and worst units will be within a few percent of each other
    So they could all be capable as P motors, they just sort the best ones as a marketing thing and maybe it helps with warranty cost by that same couple percent
    Then they software limit actual acceleration based on which model you paid for
    This also avoids a TON of cost and complexity for both manufacturing and supply chain that having physically different parts would entail
  19. boriszima
    boriszima Member
    Los Angeles
  20. ebmcs03
    So Cal
    Wait so why is there a difference for the 2017 models?
