Tesla adds titanium plate to protect against battery fires | Consumer Reports
Discussion in 'Model S: Driving Dynamics' started by Calvin.K, Apr 1, 2014.
  1. Calvin.K
    Calvin.K Member
    Stevens Point, WI
    #1 Calvin.K, Apr 1, 2014
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    So three fires is several? (Only two were road debris relates anyway so 'a pair')
  3. Trnsl8r
    Trnsl8r S85 2012-2018, X90 since 2016, 3 since 2018
    San Jose, CA
    Plus he is walking underneath the battery pack making it sound like the titanium plate will cover the entire battery pack (whereas this forum has found it's only in the front). Possible that's what he thinks, but he should do better research first.
  4. markb1
    markb1 Active Member
    San Diego, CA
    Didn't we establish that the titanium is only forward of the battery pack?
  5. dsm363
    Nevada
    I really wish auto journalists would at least do minimal research before reporting.
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Yes, that seems certain. All the new "shield" pieces are forward of the pack with one piece at the leading edge of the pack.
  7. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Not to be a smart-ass, but yes, 3 is by definition "several" (More than two, but not many).
    Either way, not a very well-put-together video.
  8. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    There is one roughly 3" diameter by 14" extrusion which is attached to the aluminum cross member which acts to chew up or otherwise excite debris for exit from under the car. This extrusion is Ti. There is also a thin flat aluminum plate which fills the gap between the rear cross member and the leading edge of the battery.
    It is an incredibly elegant solution.
  9. dsm363
    Nevada
    Only two were road debris though. The other was ramming through a concrete wall at 100 mph which this fix doesn't address. I realize several can technically cover it but If it is only two or three he should say that.
  10. markb1
    San Diego, CA
    I think it's actually an aluminum extrusion and a titanium plate. At least, that's what Elon says: Tesla Adds Titanium Underbody Shield and Aluminum Deflector Plates to Model S | Blog | Tesla Motors
  11. scaesare
    scaesare Well-Known Member
    NoVA
    This.
    Three pieces are described: a leading round hollow aluminum crossmember, a subsequent flat Ti plate, and then a shallow-angle aluminum extrusion. In the "main" thread on this subject (which I expect this will eventually get merged in to), we have pictures where the last 2 items are visible.
  12. lolachampcar
    WPB Florida
    That makes more sense. Thank you for the correction.
  13. ecarfan
    San Mateo, CA
    That Consumer Reports video was shockingly inaccurate. The description of the titanium plate was wrong, there was no mention of the two aluminum pieces, and calling TWO road debris accidents "several" is simply wrong.
    It would have been so easy to get the facts right
  14. zdre
    zdre 40kWh Model S, Model 3LR
    St. Louis
    Here is what the aluminum extrusions and the titanium plate look like. They are installed in the front of the battery to protect the 90° angle in front of the battery and deflect or crush anything that impacts it.
  15. markb1
    San Diego, CA
    Wow, that plate is much smaller than I imagined. Thanks for the pics!
  16. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    That can't be more than $50 in parts. Add in $125 for an hour of labor and we're looking at most $5M to retrofit the entire existing fleet of 30k cars.
    Going forward there's no way that's going to affect margins in any measurable way on new cars. Smart business and good engineering here.
  17. JPP
    JPP Active Member
    SF Bay Area, CA
    CR needs to go get the update/upgrade, then put their S back up on the lift and have a look-see. Then maybe they could get their report correct. zdre has the photos above, I've had it installed. See many other cross posts on the subject.
  18. Splunge
    Splunge Member
    Florida
    I had mine installed today. 2014-04-01_21h56_44.jpg 2014-04-01 21.46.40.jpg 2014-04-01 21.46.32.jpg 2014-04-01 21.46.23.jpg 2014-04-01 21.46.16.jpg 2014-04-01 18.36.08.jpg
  19. DaveT
    DaveT Searcher of green pastures
    Texas
    Did you get all three pieces installed? Could you post photos of those as well?
  20. clintons
    clintons Member
    NC
    Happy get a good visual of the completed installation. It's hard to imagine any aerodynamic penalty as the modification appears to fit flush with the battery. I assume that the plastic shield must be trimmed back to accommodate the visible aluminium piece? Maybe some Speed Tape would close that gap.
