That ship has sailed. We're all Guinea pigs, here.
I'm sure this is a result of the NHTSA investigation and is the remedy they were forced to implement. This isn't cheap. Its the most expensive solution I could have imagined short of changing the battery chemistry.
Titanium is cathodic to aluminum. Hopefully they will provide insulation between this new plate and the aluminum armor or we will certainly see corrosion of the aluminum.
Yeah, I hope they figured in preventing possible galvanic corrosion into the design with dissimilar metals.
This is my car I just picked up 2 days ago. I don't know, but I don't see anything. Maybe the black panel under the front part of the car is new?
That silver-gray metal piece just in front of the battery looks new. That black panel is a plastic aerodynamic shield that has always been there.
For the rare piece of debris that remains intact, we added a third shield, which is a shallow angle, solid aluminum extrusion that further absorbs impact energy, provides another layer of deflection and finally causes the Model S to ramp up and over the object if it is essentially incompressible and immovable.
There was some sort of bar there previously:That silver-gray metal piece just in front of the battery looks new.
Simply quoting what is in the original Twitter feed in the first post.
"...they would still have been safely protected by the steel and ceramic firewall between the battery pack and the passenger compartment."
> corrosion rapidly forms on the aluminum [Mobster]
So once this corrosion has set up shop, providing a significant electrical resistance, we can then apply opposing voltage (from a small power supply) to counter this current flow. A comparator IC could maintain a ~zero voltage differential at all times between the Ti plate and the aluminum frame of the MS. QED, no?
Or, using marine practice, a sacrificial metal could be attached. Al might be too far down the scale to find a sac metal, tho.
You have the perfect opportunity to find out the weight difference between the two cars. Would you mind taking them to a scale (not that I advertise taking a model s to a landfill, but most landfills have a scale)?Here is a photo of the leading edge of the battery of the S85 my mother just took delivery on this week (taken from just behind the passenger side front wheel) showing what I believe is the new "Aluminum Deflector Plate" that Elon discussed in his blog post:
And here is a photo of approximately the same area on my Dec. 2013 delivered S85. Obviously there is no deflector plate:
What I am not yet clear on is where the new "Titanium Underbody Shield" is located. Is it forward of the new deflector plate, or built into the bottom of the battery case? (Though the bottom of the battery case looks the same in both photos)
I'd guess it either replaces what used to be the black plastic panel in front of the new cross bar or it's just above it.What I am not yet clear on is where the new "Titanium Underbody Shield" is located. Is it forward of the new deflector plate, or built into the bottom of the battery case? (Though the bottom of the battery case looks the same in both photos)
