Definitely! Version 2.6 is a matter of days away but I will PM you a preview of it.Nice job. I got your latest installed on my windows pc. Any plans to expand the information from the powerwalls?
My app?The app crashes for me after login. What are the runtime prereqs?
Are you using a model 3? There is a known bug.
Should work fine then. What sort of error are you getting?I only have a Powerwall 2. Was interested in seeing what you'd done in that regard.
Got it and installed. I like the additional info for the Powerwall. Nicely done!Definitely! Version 2.6 is a matter of days away but I will PM you a preview of it.
Thanks! Next step is to include the usage data of solar, grid and house.Got it and installed. I like the additional info for the Powerwall. Nicely done!
Here's the error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: value
at Newtonsoft.Json.Linq.JToken.EnsureValue(JToken value)
at Newtonsoft.Json.Linq.JToken.op_Explicit(JToken value)
at TeslaApp.Main.f()
at TeslaApp.Main.c(Object A_0, DoWorkEventArgs A_1)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3260.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Tesla for Windows
Assembly Version: 2.5.1.0
Win32 Version: 2.5.1.0
CodeBase: file:///E:/download/Tesla-for-Windows-2.5.1.0/Tesla%20for%20Windows.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.3190.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Newtonsoft.Json
Assembly Version: 11.0.0.0
Win32 Version: 11.0.1.21818
CodeBase: file:///E:/download/Tesla-for-Windows-2.5.1.0/Newtonsoft.Json.DLL
System.Web
Win32 Version: 4.7.3282.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Interesting...
What powerwall firmware are you running? Other users do not encounter the same issue as you.
No I hadn't taken into account UK powerwalls being different and that might be the issue. I only have US and aussie units to test.I've got a couple of UK users (@spoonwzd was using it - or at least I was trying to get it so that it could be used at one point) using my control service, and one thing that tripped me up is that if you don't have a backup gateway (this isn't available in the UK) then certain things break.
The telltale appears to be that https://powerwall/api/powerwalls doesn't return the has_sync element (missing entirely), and the GUI shows that backup capability is missing.
Given the null error, I wonder if that's the problem - your app is hitting a missing element for a UK powerwall?
You're the first UK user I've encountered so the API must be different for you. If you'd like to help Me solve the bug I'll need some sample API requests from your account. PM me If interestedCurrently running 1.29 firmware - and yes I am a UK user as BJ suggests![]()
PM me and I'll investigate. Works fine for me.Is this app still working? I just installed - however I am not able to login.
If you have a Windows PC my app can do what you want.
Tesla for Windows - The ultimate Tesla app for PC
Also I can try making some bash scripts if you want for the raspberry pi. PM me.
yeah sorry its written in VB.NET so not exactly cross platform friendly.I just found this post. I’m one of those UK/ Linux (or OSX) guys. I have no Windows (that includes Wine and other emulators). As the post is about three months old I thought I’d ask if you’ve git a working Linux or OSX version of your app? I see the UK bit is covered in latest Windows release.
Would be happy to do a bit of testing on non-Windows platform if it jnterests you.
