There is a storm here in northern California but Storm Watch wasn't triggered so I decided to top off my Powerwalls from the grid. I enabled charging from the grid and set my reserve to 100%.
The app is showing power coming from solar (which is more than is possible on a rainy day) and the grid but showing my home isn't consuming anything. My 3 Powerwalls are showing charging at a rate of the sum of the solar "production" and grid consumption.
When I directly connect to the Gateway using the IP address the grid consumption and Powerwall consumption match the Tesla app but it shows my house consumption value negative (but the absolute value in the right ballpark) and has a yellow triangle with an exclamation point saying "Warning: Load meter may be configured incorrectly" when I click on it. The sum of the grid consumption, solar production, and house consumption (when changed to a positive value) match the Powerwall consumption.
I suspect there something incorrect with the CT settings. When I'm not charging from the grid the Tesla app and Gateway readings appears to work correctly (including during a power outage).
Is this normal for grid charging with solar, does anyone else have this problem?
