Tesla app showing zero home consumption after solar upgrade
Discussion in 'Tesla Energy' started by Dukeybootie, Feb 24, 2021.
  1. Dukeybootie
    Dukeybootie Member
    United States
    Had additional panels wired in to my existing system yesterday and they went online without issue. City inspectors came this morning and gave their blessing. However, since the new panels went online the app has started showing the home consumption dropping to zero for extended periods of time. I am never lower than 0.3 and everything seems normal inside the house. Could this be an issue with gateway settings? Any thoughts?
    (am trying to contact the installer for help but still waiting for response)
  2. Dukeybootie
    Dukeybootie Member
    United States
    Screenshots attached
  3. jjrandorin
    jjrandorin Moderator, Model 3, Tesla Energy Forums
    Riverside Co. CA
    What are the rest of your loads during those times (solar, powerwall, grid)?
  4. getakey
    getakey Member
    probably another CT installed wrong issue
  5. Dukeybootie
    Dukeybootie Member
    United States
    Everything else looks fine. Loads shifted as expected overnight with TBC cost savings. If the CT installation was the issue, I feel like the overnight situation would not have looked as it did. But I'm not absolutely certain.
  6. jjrandorin
    Riverside Co. CA
    Can you provide a screenshot with all 4 locations on (you turned off the home load button in the last one). Just trying to see if anything jumps out, but its hard when they are not all there at once.. at least for me.
  7. Dukeybootie
    Dukeybootie Member
    United States
    Sure
  8. power.saver
    power.saver Supporting Member
    Arcadia, CA
    Did you get another inverter for the new panels?
  9. Dukeybootie
    Dukeybootie Member
    United States
    Yes. The original inverter still exists as well.
  10. charlesj
    charlesj Active Member
    Monterey, CA
    I had some of those issues not long after PW installation. My CT antenna in subpanel wasn't properly installed and house showed no consumption at time. Gateway was not getting CT signal some of the time.
    Problem solved when the next tech dropped it into the wall cavity instead of being inside that metal subpanel.
    You may have similar issues?
  11. jjrandorin
    Riverside Co. CA
    maybe that second (new) inverter / panel setup is generating enough power during that "no load" time frame to cover your loads, but is not registered with your account (or CTs not monitoring it)?
  12. Dukeybootie
    Dukeybootie Member
    United States
    This explanation makes a lot of sense. As if the baseline to detect house loads was elevated, perhaps?
  13. jjrandorin
    Riverside Co. CA
    Well, I am thinking of it as the new equipment is providing enough power to cover the home load, but it isnt being captured properly in the app due to either CT mis configuration or new inverter not registered with app. Since there is a new inverter, I would imagine for it all to be captured there must be another CT for it.... but I admit freely to not being as technical as some of our other members on this stuff.
    I was just looking at the time frame that shows "no load" and its right in the middle of the day, when max PV generation likely is.
  14. getakey
    getakey Member
    that makes sense to me. to the OP, has your solar production gone up?
  15. Dukeybootie
    Dukeybootie Member
    United States
    Yes, you can see the spike in solar production on yesterday's overview shortly before noon. Which is coincidentally the same time when the house loads dropped to zero on the app, further reinforcing jjrandorin's theory.
  16. getakey
    getakey Member
    I mean has your production gone up from what is was before you added more panels?
  17. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    I have the same issue but mine might be a different problem. The circuit that my new solar is on was a load before and Tesla did not move it over to the solar CT. It rarely has any load on it. So when solar is produced on that inverter it gets subtracted from the Home load, often showing zero during production. The remainder does show up as solar. Tesla needs to move that circuit over to the solar CT IMHO.
    Also I talked to my installation manager yesterday and he ask if had gotten a black box to plug into my ethernet. I had not. He thought that would take care of the problem too. I have a Delta inverter.
    Anyway that is my story and waiting for Tesla to either give me the black box and/or move my circuit to the solar CT.
    This picture shows the PWs at 100% and the solar covering all the house load plus remainder spilling over to the grid. House load is estimated at 800-1000 watts.
  18. Dukeybootie
    Dukeybootie Member
    United States
    Not sure if I am answering correctly so I've included the last couple days of solar production from the app. On 2/22 you can see the production rate peaks around 5 kW. On 2/23 you can see the big jump to 7 kW shortly before noon when the new additional panels went online.
    As I was going through these graphs, I am noticing the smooth parabola on 2/22 versus the jagged outline ever since the new additional panels went online. Almost certain now it is linked to the house load and the new panels' production is going to the house first, with the remainder being added to the old panels' production.
  19. power.saver
    Arcadia, CA
    It is likely they wired the new inverter into your panel without running it through the CTs for your original inverter. That would cause the home load to be reduced by the amount your new inverter is producing, and not have the new production registered as solar.
