You keep bringing that up as if that is somehow going to change the fact that Tesla has almost a million cars with a similar sensor suite and the next million has no indication of changes.
Uh... that's not true at all.
They only broke 1 million total cars THIS quarter.
A couple hundred thousand are AP1 or no AP at all.
Another big chunk are AP2.0 (different sensor suite)
Some more are AP2.5 (different computer from what's now "needed")
Every time it changed they assured everyone NOW the car has ALL the HW it needs for FSD!
And they've been wrong multiple times so far.
They would have realized that in the past 2 years.
- We would have seen changes go into Model Y to the sensor suite.
- just like we see a heater on the radar in the Model Y.
So does that mean the S/X/3 cars without it don't get FSD in the snow?
Because that seems a great example of finding out most of those (not really a million) cars setups weren't good enough
I mean- they made a ton of HW2 cars back in the day... and turned out they eventually realized that was insufficient.
HW2.5 came along- different sensors (camera filters are different, front radar is different, computer and wiring different, etc)
Then THAT computer was not good enough either- HW3 computer (and extra work to get it to operate correctly with HW2 sensors- still unknown if there'll be functional differences there)
Then it turns out the fundamental design of AP just was not going to work... so they're
currently rewriting it from the ground up
(done soon allegedly)
So they've repeatedly found the HW wasn't good enough- but it took a while between each thing.
Now they've found the SW core isn't good enough and they're redoing that.
Unknown if they then find more sensor shortcomings after they get data into the new SW.
And remember these are the folks who originally promised a cross-country FSD drive by "next year" since 2016.
It still can't drive across
town that way though in 2020.
But IFF the sensor suite is insufficient, then you are correct, no amount of data from the sensors would be enough.
Right- so insisting they'll get FSD as originally promised working on this HW because "DATA" is assuming facts not in evidence.
If for example it turned out you really DO need LIDAR for L5, some other company with much less DATA, but all of it using LIDAR, will get there first.
(FWIW I don't actually think you DO need lidar- but I DO think you need more than the current AP2.x sensor suite- at least a few more cameras, ideally better ones, and I wouldn't object to rear and maybe corner radars though with enough of the right cameras could probably live without em)
