Mayhemm
Model S P85+ "Lola"
It's rumored that it will eventually take as long as 135s :tongue:
Unacceptable! I'm cancelling my order right now! :biggrin:
The actual swapping device doesn't have to be below ground. The only requirement is for the car to have enough clearance for the robot to work under it. Lifting cars so they can be worked on isn't an untried technology, so I doubt that would be much of an issue. The actual robot swapper doesn't seem like it would be a particularly large or complex device either, so making it mobile seems quite doable.
My concern with the swapping system is its complexity. There have already been multiple reports of non-functioning superchargers for one reason or another; and they are an order of magnitude simpler than a battery swapper.
How well do you think that robot swapper will function when it's buried in half-frozen dirty slush at -20 degrees? Given Tesla's spotty record with cold-weather preparation, I'm inclined to think "not well".
Nope: the real unsolvable problem is: variability of battery formats.The only question is: How low can they make the cost of the process?
Swapping stations would always be manned, and even temporary ones could easily be covered, so I don't see that as a major issue, although it certainly would have to be designed for.My concern with the swapping system is its complexity. There have already been multiple reports of non-functioning superchargers for one reason or another; and they are an order of magnitude simpler than a battery swapper.
With battery swapping up and running, Tesla will need to make a tough decision when designing new model:
a) use same battery format as existing models and suffer performance tradeoffs (vehicle dimensions, range/capacity, weight, ...)
b) introduce new battery format and upgrade ALL swapping stations with yet another battery format
Both options are bad and very bad, depending of POV.
Battery swapping could work with a single, unchangable battery format. I don't want to live in world as limited as that.
GenIII will have physicaly smaller battery. GenIV will again be different, future roadster once more.
The whole BS is just marketing BS. Don't hold your breath.
- - - Updated - - -
Of course, both problems disappear if swap stations stay limited to a few distinct locations.
It is not costly nor hard to supply a few swappers with all distinct battery formats.
But having only a few swappers is same as having no swappers for most drivers.
The faster Tesla can make Supercharging charge, the higher volume they can support, but the current charging rate is not fast enough to support high volume. With success, they should be able to add spaces, but there would be logistical limits. So, if they can't beat the contention with fast charging, they would need Superswapping. They don't like it, they don't want it, but there's a high-sales reality they'll hopefully have to deal with.
Tesla is planning for the future. The Distribution center going into each site is rated at 2000A, 480V, 3-Phase. Even small, 4-bay sites like Farmington and Blanding are connected to the transformer with 3, 500MCM cables per phase that give a capacity of 1290A without pulling more wire. Today's 120kW Superchargers pull 160A and the breakers in the Distribution centers are very fancy that can run at 100% of rating,
Superchargers will never be as fast as Superswappers, but are a lot cheaper to install and simpler to maintain. My guess is the Superswappers sites will be limited to just a few of the busiest locations.
Tesla is planning for the future. The Distribution center going into each site is rated at 2000A, 480V, 3-Phase. Even small, 4-bay sites like Farmington and Blanding are connected to the transformer with 3, 500MCM cables per phase that give a capacity of 1290A without pulling more wire. Today's 120kW Superchargers pull 160A and the breakers in the Distribution centers are very fancy that can run at 100% of rating, Schneider Masterpack Circuit Breakers This means that even little 4-stall, 2-Supercharger sites are already configured, with a transformer change to grow by 4x to 16-stall, 8-Supercharger sites.
My personal preference would be to also focus on many more Supercharger sites. This provides geographic diversity for grid failures and makes it easier to find Superchargers on your route. With many more Supercharger sites, more stalls per site, and good Supercharger status reports in the car via the Nav or other apps, Supercharging will be robust and pretty darn fast.
Imagine all cars on the road are Teslas with a 60kWh battery.
I hope we need swapping.
Imagine all cars on the road are Teslas with a 60kWh battery. Let's say it's a holiday weekend in Maine with 2-lane I-95, cars 2 seconds apart. That would mean 60 Teslas reaching a Supercharger site per minute. If they need to charge for 1/2 hour, you'd have 1,800 cars charging simultaneously. If they need to charge for 5 minutes, you'd have 300 cars charging simultaneously.
That's quite a starting premise. How about something more realistic, yet still wildly optimistic, like 1%. That divides all your numbers by 100 and seems pretty manageable.
Great point: batteries are not perfectly fungible commodities. Some have been abused and/or driven long miles; others, babied. The logistics become really tough if Tesla is going to loan me a pack until I can reclaim mine. Particularly if I'm planning an A->B->C route. Would Tesla give a credit, or impose a charge, based on the delta between the battery I'm dropping off vs. the battery I'm getting? That seems very challenging to implement.Swap also functions well where a battery lease is offered. Since you don't own the battery, you don't care which one you get back.
$300/month all you can swap and supercharger . . .
25,000 of us already own our battery; are we excluded from swapping?
This whole swapping thing seems like a real nightmare to implement commercially. I'm also not crazy about the prospect of Tesla hiring more staff, 24x7, to man these stations. Surely the company has more pressing ways to spend its capital to foster growth?
