Thanks for the links. Solid state batteries are certainly one of the two or three most promising directions battery research is going right now.
I don't think EVs are the first place you'll see them, though. With higher margins, lower life requirements, and more need for the durability and temperature tolerance, cell phones and other personal electronics will likely get the solid state batteries a year or two before cars do. They can probably also take early batches where the quality/yield is more of an issue more easily.
Solid electrolyte, aka solid state, enables a lithium metal anode which saves a lot of weight. Today's solid state (or semi-solid state) cells can achieve 400+ Wh/kg, but suffer from low power density and low cycle life.Wat?
Not sure what else they are eliminating, but electrolyte is less than 2% of mass per http://www.ipd.anl.gov/anlpubs/2014/11/109509.pdf
Are Tesla investigating Solid State batteries or would they work with a Vendor?
As far I know, dry electrode tech has nothing to do with solid state batteries.With dry electrode, solid state batteries, there is less concern about fire if the batteries are crushed, so there is less need tor some kind of container to reduce the crush risk.
The term "solid state" means no liquids (or gasses) in the device.
Mader is correct. "Dry Electrode" is the technology that Maxwell developed for depositing electrode materials on the current collectors. It replaces the solvent previously used, but even with the old solvent based coating once they were baked there was no liquid left behind. Solid state batteries could be made with the wet solvent process because the solvent is removed. What makes a cell "solid state" is the replacement of the liquid electrolyte with a solid or polymer. The way the electrode is coated has nothing to do with it.
Directed at Ford, not you:
Train car wheels have a rolling coefficient of friction of 0.001-0.002 so one million pounds is a rolling force of 1,000 - 2,000 pounds, a fraction of the weight of the truck itself. The rest of the force needed is just accelerating the mass.
This guy pulled over a half million pounds of train with his teeth:
Heaviest train pulled by teeth
Tesla has done the same sort of thing:
The Quantas X pull Tesla SUV earns a Guinness World Record for towing massive airplane was a quarter million pounds. However, the tire coefficient is higher, so if the c was > 0.004 - 0.008, the X pull required more force.
(also, train pull impressiveness varies based on the slack between cars and slack in the pull strap. Jerking the first car to roll which then jerks the second and so on is much easier than if the train is has no slack).
Why do you suppose Ford - a self-described "big, tough macho, American truck company, who makes work trucks aimed at hardworking dudes" used an Asian female for the driver / representative in this ad? It seems very out of character and contrived to me. They almost always just use the stereotypical white male in their truck ads. What message are they sending here? I don't remember them doing anything like this with their "military grade aluminum" campaign. Honestly, I think they are trying to sissify it with this message. Or at least cause some mental confusion.
1) Because Linda Zhang is the F150 Chief Engineer. Do you think they should replace the actual Chief Engineer with a white male actor to fit the narrative you think should be presented?
2) In the typical F Series buyers group is an Indian guy with an accent, who is definitely not a European-American. Or a Bubba with pickup.
3) I honestly don't think they are trying to sissify it. I think you are seeing ghost where none exist.
I scrubbed through it once it started reminding me of the cheesy Chevy commercials these days bragging about their awards; and with contrived commentary, so I had no idea she was the F150 Chief Engineer. That's cool. Regardless, I don't recall Ford trotting out their engineers to talk about "Military Grade Aluminum", but maybe they did for the initial reveal. I do strongly remember macho Idiocracy-like voice-overs boasting about how tough it is. Upon Googling - actually it was an obnoxious Denis Leary - with super-quick cuts and geared to testosterone. Just a totally different vibe. I would guess Ford knows their target, but I'm not on Madison Ave.
Ford F-150 TV Commercial, 'Military Grade'
Believe me, I hope you are 100% right.
