I seriously can't believe that I'm wasting more time on this yet again, but I can not sit here and let you spread additional non-information without additional reputable opposition.
We do not have agreement on anything apparently. I consider making sure the fuel use (gasoline, diesel, propane, hamsters in wheels, or batteries) by the motors for testing to be a vital part of running a motor/engine and for an accurate measurement of a motor built for a specific application, such as in a a car. You apparently do not.
Not sure where I ever said to put diesel in a gasoline car or vice versa. lol. Seems to be some more fluff for you to throw out to make it, again, appear like these arguments actually have merit.
At least we agree that an ICE will run differently if given different fuels. Extend that to the motors behaving differently with a different power source and we're finally getting somewhere. The former isn't permitted, or would immediately be seen as fraud if used to inflate numbers. You want to allow the latter even though it's the exact same thing as the first for the platform at hand.
While your (and Tesla's) interpretation of ECE R85 is definitely in question as far as I'm concerned, I fail to see the relevance of anything I just quoted above. We know how Tesla came to the numbers now thanks to JB Staubel's admission. They tested the motors, individually and independently of the battery and simply summed up the numbers. I'm pretty sure this had been accepted as the official source of the 691 HP number. So I'm not sure the point of the above excerpt. No one is questioning how they arrived at the number anymore, since it has been explained. The problem is the fact that the method they used to arrive at the number is complete BS when used as a spec for the P85D, the car. Again I point out that we bought *cars* from Tesla. Not motors. If I had bought the front and rear motors from Tesla... just the motors... and they gave me an invoice saying they sold me 691 HP worth of motors, I would have no argument. But they sold me a 691 HP *car* that can not produce 691 HP. How is this even in question, especially after admitting it in their own blog?!
At least for this, I think we both misunderstood each other. I was not saying that the motor would output max HP at any RPM. JB was referring to the summed motor power ratings, which is a static number, which makes the sentence in question false. (515 kW < 415 kW)
However, building on that, let's say the car was bolted to the ground, all four tires and the drive units unable to spin at all. The inverters were then commanded to produce maximum power. Now, the motors are not able to spin, but they can exert a force against their entrapment equal to the amount of power input... at 0 RPM... likely ending with the death of some components. This seems counter intuitive, but it doesn't change the definition of 1 HP (electric) being ~746W. The input power doesn't just disappear because the shaft isn't turning. Exactly how much power could be input in this situation I don't know for sure, but I'm damn sure it's far more than represented by the graphs you posted.
I'm not sure if this is true or not, admittedly, because history is definitely not my field. Second hand, a reliable source (real world older friend who is very knowledgeable in auto history) tells me this is nonsense.
Logical thinking, however, is a pretty strong suit of mine. So logically, even if the reasoning for adoption were in fact to under advertise power due to a temporary fuel crisis, why maintain and utilize the same standard for 40+ years after the situation had passed? I mean, people want cars with high horsepower regardless of fuel economy these days when buying a powerful vehicle. No one looks at horsepower ratings as a measure of fuel economy these days, so why doesn't everyone just use SAE gross again to make the numbers look better if that's acceptable? Oh, because inflating the numbers isn't actually acceptable. DOH!
I think what I point out is the core point of my analogy that you responded to originally. The crux of the issue here is whether horsepower standards must reflect the system as a whole, so I gave an example where it doesn't: SAE Gross hp. That horsepower standard characterized the engine, not the system as a whole. I hope we have agreement with that. I see this as an exact parallel with "motor power" in this case (which characterized the motor/inverter and not the system). And it also happens that the end effect in terms of percentage is very similar.
I see the fuel analogy as kind of a side point and a very imperfect one. In your original example, you said diesel and gasoline. If you put diesel fuel in a gasoline engine and vise versa, will likely not even work (and will damage the engine). An ICE can tolerate some fuels, but it will run completely differently even if you put the fuel with the same equivalent amount of energy. It is very hard to match up such an analogy with a DC power source, where what matters is the voltage and current (not the characteristics of the DC supply other than that).
I've been in arguments over ECE R85, the power rating standard Tesla uses in the EU, which doesn't specify that the motors must be tested with the DC source as installed in the car (while it does for the accessories attached to the drivetrain). I have been waiting to be corrected on this point, but it appears to be 100% true, esp. after Straubel's statements.
In fact, a poster pointed out a line on page 9 that seems to suggest that the standard does not expect the manufacturer to use the factory installed battery during test:
"Note: If the battery limits the maximum 30 minutes power, the maximum 30 minutes power of an electric vehicle can be less than the maximum 30 minutes power of the drive train of the vehicle according to this test."
http://www.unece.org/fileadmin/DAM/trans/main/wp29/wp29regs/2013/R085r1e.pdf
That statement seems to match with Straubel's statements:
"Since the battery electric horsepower rating varies it is not a precise number to use for specifying the physical capability of an EV. The motor shaft horsepower, when operating alone, is a more consistent rating. In fact, it is only this (single or combined) motor shaft horsepower rating that is legally required to be posted in the European Union."
I have seen the claim by others that electric motors can always output their peak power in the low rpm ranges, but I don't believe this to be true. Horsepower is a factor of torque and rpm. At low rpms, the peak torque of the motor limits the amount of power it can output. And given the torque is a direct function of input current, which is in turn limited due to inverter and the current limit of the motor windings, it would be impossible for the motor to output peak power at the lower rpms.
This is more readily shown with a power curve of a car that is not traction nor battery limited (the Roadster; if you doubt that, you can look up a Leaf power curve too):
(graph)
Here is the power curve of a UQM Powerphase motor (not installed in a car):
(graph)
In both cases, the peak power is not reached until later in the power band and it does not appear to have anything to do with traction, but rather because the motor is hitting its maximum torque limits at the lower rpms (the graphs seem to make that clear).
Look at the history. Car manufacturers did not switch to net power ratings in the 1970s because they wanted to be more honest. They switched because during the fuel crisis, it was bad to be seen as making a car with irresponsible amounts of power (it was the time when CAFE fuel economy standards were introduced). Switching to net power gave them a convenient way to adjust their advertised power numbers down without having to reduce it in real world use.
