Tesla CAN bus logging/display with Raspberry Pi
ben.krasnow
15
90
SF Bay Area
I posted a video about my project in which I use a Raspberry Pi to display realtime CAN bus data in the car's own web browser.
Let me know if you have any questions. -Ben
Shortcut to the links:
I show how to collect detailed CAN bus data from a Tesla Model S, and display it in the car's own web browser!
Complete Raspberry Pi with CAN bus shield and 12V buck converter: Raspberry Pi 3 System With CAN Bus Interface
Diagnostic connector pinout (scroll through the images):
EVTV Motor Verks Store: Tesla Model S and Model X CAN Monitor, OEM Electric Vehicle Items, TeslaCANKit
Tesla diagnostic connector: Tesla Diagnostic Cable For MS/MX (Sept 2015 and up) - Bare Wire Version
RPi CAN bus tutorial: CANned Pi: (Part1)
Get node.js installed on the RPi: Guide to Installing Node.js on a Raspberry Pi | thisDaveJ
I used socket.io, which is a module that installs into node.js: socket.io
Basic sequence to setup the server on the Pi:
sudo ip link set can0 type can bitrate 500000 listen-only on
sudo ip link set can0 up
candump -cae can0,0:0,#FFFFFFFF
candump -cae can0,0:0,#FFFFFFFF | grep 106 | awk -Winteractive '{ print $10}' | node app.js
Tesla CAN bus reverse engineering: wk057's SkieNET
I will post the node.js code on my blog:
Ben Krasnow
Skysurfer
79
80
Iowa
Very nice work. Thank you for posting this! I have been searching for a decent Linux CAN setup for doing analysis on my Model S. This will certainly improve over the current Android setup I have and looks like I may be able to feed in some old captures I have for better analysis.
Looking forward to the ultimate graphing/performance monitor you are working on!
Wonder what the best solution is to keep the Raspberry Pi firewalled from the internet connection? Maybe acting as a bridge or some other clever routing manipulation can accomplish this.
Drewflux
272
96
Australia
Great work Ben. I enjoyed your first video. I have a question on getting the web browser to connect. After the initial connection, could you remove the usb tethering?
