The signed and sealed engineered drawings (and agreement) called for the following for my 17kW PV system:
I just checked what was actually installed and found the following:
Is this something that I should be concerned about?
Now, my panels are grouped by the following, which may determine how many panels each inverter receives:
- Solar Edge SE10000H-US (10kW) inverter with 28 panels at 340W each, totaling 9.52kW, or undersized by 4.92%
- Solar Edge SE7600H-US (7.6kW) inverter with 22 panels at 340W each, totaling 7.480kW, or undersized by 1.59%
- Solar Edge SE-3800H-US (3.4kW) inverter with a yet to be determined amount of panels. The designed was slightly changed, I still have (50) 340W panels for 17kW total, but the layout is different.
- Solar Edge SE-11400-US (11.4kW) inverter with a yet to be determined amount of panels. The designed was slightly changed, I still have (50) 340W panels for 17kW total, but the layout is different.
- (20) 340W panels totaling 6.8kW
- (15) 340W panels totaling 5.1kW
- (7) 340W panels totaling 2.380kW
- (6) 340W panels totaling 2.040kW
- (2) 340W panels totaling 0.68kW
