Hello:
When you use the tesla owners API to issue commands to powerwall / gateway as we do here:
'owner-api.teslamotors.com'
fkhera/powerwallCloud
Any idea how to avoid the 15-20 minute delay between calling command and having it take effect on the gateway?
When I used to code locally I would call a separate commit statement:
vloschiavo/powerwall2
GET & POST /api/operation Change the Powerwall mode and Reserve Percentage
Note 1: Making changes to the Powerwalls via the Mobile application can take some time to go into effect. There's a rumor that states that the changes happen around 30 minutes past the hour. (Probably based on a cron job in Tesla's servers).
Note 2: Setting a value is not sufficient to make the change. You must "save" or "commit" the configuration to have it go into effect. See the Config Completed section below.
Note 3: Once a value is changed and committed it is immediately in effect
From what I recall I had to call a combination of::
GET /api/sitemaster/run UPDATE: You need to be authenticated for this command This starts the powerwalls & gateway. Use this after getting an authentication token to restart the powerwalls.
Request: curl --cacert cacert.pem https://powerwall/api/sitemaster/run
Response:
Returns HTTPS Status 202 if request is accepted
GET /api/config/completed UPDATE: You need to be authenticated for this command This applies configuration changes.
Request: curl --cacert cacert.pem https://powerwall/api/config/completed
Response: Returns HTTP Status 202 if input accepted
Response:
