Candleflame
This has been known to likely be the case for over a month, since late October, through inference from the EPA documents. Post to this effect here.
Preliminary EPA Data for Model 3 AWD & Model 3 P 2021 Released
These are just numbers on a piece of paper. Nominally the battery is claimed by Tesla to be an 82kWh pack.
We can do some math on this, with known capacities and the claims about the increased capacity.
Prior packs: 79.5kWh (pretty consistently has been in this ballpark in EPA, it's a good estimate for 2018-2020 pack capacities). (Note that in some recent Tesla gov't documents similar to what you posted, these have been labeled as "75kWh" - so clearly the capacity on such labels is just a very rough guide.)
New packs: SMT reads back 80.2kWh, so EPA value would be around 81kWh based on past experience (EPA test value was 80.8kWh as graphed above by @Zoomit, and as I reported here in detail when the document was released over a month ago)
If we actually believe a true usable 5% capacity increase (eventually) we can say that in future, the new pack may be expanded in EPA testing to allow:
79.5kWh*1.05 = 83.5kWh. (EPA test energy)
Note, this isn't happening yet, and we have no idea whether it will ever happen. Also note that SMT readbacks will never show such a value, since they are always offset lower from the EPA values (for energy of 83.5kWh you'd expect maybe 82.5kWh in SMT). I imagine the capacity limits are driven by safety concerns and validation of the new cell construction safety profile. I guess people with SMT should start paying close attention to the voltage limits (high and low) on the new Performance pack and compare to prior readings on the older cell type, to see if they are obviously different. You'd expect them to be if they're artificially limiting capacity...I think. Perhaps @Zoomit could comment on that.
Anyway, if you view it from that perspective, you have nameplate 75kWh packs with 79.5kWh capacity, and 82kWh packs with 83.5kWh (potential) capacity. Again, to be clear, right now the Performance packs have about 81kWh capacity, reading out in SMT at about 80.2kWh.
We'll see what the future holds! I've said for over a month that the new "82kWh" pack in an AWD non-P vehicle would yield EPA range of around 370 rated miles. But right now they don't appear to be building them this way. To get that (approximately), you have to get a Performance vehicle and find a way to put the new 18" aero wheels and new MXM4 tires on it. Which sadly is not a bolt-on possibility. And ignore the incorrect constant. And they'd have to unlock just a little bit more capacity...you'd only get ~363 rated miles right now.
it is not. 79.5 kwh was only due to the low battery demand which can draw a bit more wh from the batteries, if you drive it normally the batteries when new would release 78.8-79kwh. if you take 4.5% away from that for the buffer you end up with 75kwh for 0 to 100% pretty much exactly.
With the old labeling the 3 would have clearly been a 3.75D or 3.55. I am sure the fact that the 3 has a number rather than the letter E is part of the reason for the long range change. (Together with people being unhappy that the number usually doesnt reflect the actual available capacity)
