1. OVERCHARGE, OVERCHARGE, OVERCHARGE!
My Model S has a maximum range of ~240 miles. Depending on the terrain and weather, I burn through >50 miles more than actually driven. The car rating is fairly accurate, but it does not account for extreme cold or heat, heavy use of Heat/AC, inclines or traffic.
2. Reduce energy consumption to skip charging stations.
If you want to avoid stopping every 2 hours or less, reduce your energy consumption in the car and charge as close to maximum range as possible. If you charge close to maximum range, the navigation will automatically skip charging stations. This greatly reduces your time on the road. CAVEAT: If you don’t have at least 10% battery predicted at your next charging spot (this is listed next to the destination on your navigation screen), you may not make it. Search a closer supercharger or charge more before continuing your trip.
3. Drive methodically.
Do not risk driving between superchargers with barely enough range. You must charge beyond 210 miles when you are in the middle of the country or you run the risk of being stranded where there is absolutely nothing.
4. Beware of Inclines.
Inclines burn an inordinate amount of energy. The terrific inclines on I-80 between CA and NY are (a) Sacramento, CA to Truckee, CA; (b) Winnemucca, NV to Elko, NV; (c) Salt Lake City, UT to Evanston, WY; and (d) Strongsville/Cleveland/Akron, OH to Falls Creek, PA. Charge to maximum range and conserve energy in the car.
5. Weather
The stock Tesla tires are not rated for any type of weather. The 2wd Model S is NOT a snow car. In the snow, the regenerative braking caused my Model S to slip and the traction control did not prevent the slippage. Bottom line: If your Tesla is not AWD, consult Tesla before driving in the snow and carry chains.
6. Be kind to your supercharger sponsor.
Most I-80 superchargers sit in hotel, gas station or grocery store parking lots. Please make every effort to be kind to the sponsors and keep the supercharger area clean. I made every effort to patron whatever business was sponsoring the supercharger. The hotels typically have a lobby area where you can sit. The grocery stores had cafes where you could eat. Remember, without the superchargers, it would take a month to travel cross country. You can read more about the I-80 superchargers in my post titled Tesla Cross-Country Trip, I-80 Superchargers, Nearby Services.
5. Weather
