Ok so I usually don't post complaints like this but I need peoples advice. I have a Tesla Model 3 (White) Standard Plus with Full AutoDrive. It was Delivered in March in that rush before the Quarter ended. I had scratches on my Steering wheel airbag and every single panel was misaligned. Left Passenger door was almost 1/4 inch sticking out in the closed position. I took pictures of everything and sent it to Tesla. Got a response almost immediately that I should schedule a service. I'd schedule using the app and within one day it would drop off the app- they were canceling it. This happened 3 times before I just called and asked them why they said I was in their system and they need to order a new airbag. I asked them why they couldn't let me know this was the case instead of just canceling my appointments.
I let this slide but we are in Mid June now and still no replacement airbag.
Next issue I used a fellow members technique in installing a Dashcam getting constant power from the overhead hazard light module. Installation was flawless and everything worked great. However, about a week ago I started losing all Audio from the car no turn signal noise no alarms no Music nada. I took the car in and the Tech blows me off as far as the panel alignment issues by saying we are a new company and that it's within normal limits. I was frustrated but got them to do at least some minor adjustments - Not perfect like it should be for a 50K car. Also the next day they say my T tap installation to the module needs to be reversed since its possibly the cause they weren't sure. He's not sure it is but just wants me to pay $420 to install new wire harness and module even though they work perfectly. I didn't splice the wires just used these small T Taps. They couldn't even replace the harness or module because the parts were not in stock. The sound came back on its own mysteriously on the day I dropped it off and had nothing to do with disconnecting the dash cam.
A couple of questions should I pay them to replace a perfectly good working harness and module for $420?
I have the car back and don't need to as everything has been working. Seems like a waste but I don't want them to blame any electrical issue to my install. I have disconnected by install and reconnected the wiring to the 12 V in the center consule.
