mmccord
Does anyone know who sells these "paddle gears?" If so how much and where at?
Tesla door handle failure - pivot gear (anyone have one I can buy?)
I did not. I have lots of pictures and can help with any questions though.
But sadly he doesn't ship in the US.
If I may ask, how much was it?
Thanks for the photos.
I just got an email from local Tesla service confirming they won't sell me the paddle gears.
@mmccord What would you do if your handle broke again and you didn't have a spare chr20 version of the paddle gear? Just disconnect the motor (to stop it from spinning endlessly) and use a piece of string or other latch to pull on the handle?
I 3D printed a physical handle which works well, but it doesn't exactly live up to the Model S aesthetic... Tesla Model S Door Handle Fix/Prop for Non-Retracting Handles by freerobby
@mmccord Also, are you able to confirm whether the paddle gear mechanical design is the same in old and newer door handles? My assumption has been that the updated part fixes only the microswitch issue and not the paddle gear issue, but I haven't confirmed that. Assuming so, it's pretty frustrating that a known issue could go on this long and remain unaddressed and unrecalled.
What is causing the pivot gears to break? Is it always at the hole around the pivot rod? I wonder if a (slightly flexible) nylon top and rigid ABS bottom would stand up to wear and be less likely to snap.
You know what might help...? Rubber bumper-stops of sorts or a softness in the system.. something that will give a little, squashes a bit when the slam happens. Probably don't need much thickness to help with the shock a lot... If there was some squashy "give" between the pusher arm and the handle part it pushes on ... that'd help.
Or, if the pushing part of the pusher gear was rubber, like a leaf spring, instead of rigid steel... that might help. Ideally, if something were preventing the handle from being able to extend (say frozen ice coating the door)... then this rubber pusher arm would have enough give to try its motion but flex all the way so as not to snap.. then it would never break.
Took mine apart, here is broken part. Bought complete assembly off eBay, hope it works
