Tesla Europe Registration Stats
Discussion in 'Wiki' started by Wiki, Jan 30, 2016.
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. Atlantis
    Atlantis Member
    Portugal
    For Portugal, ACAP had updated their numbers for Tesla sales in February with 124 Tesla cars sold (instead of 109) with 97 of them being Model 3. With the 15 Tesla sold in January and then the 355 in March (don't know yet how many were Model 3), the total number for Q1 should be 494.
  2. Troy
    Troy Active Member
    #202 Troy, Apr 3, 2019
    Hi, @AndyH. We are using Nyregistreringar for Sweden. We could switch to the website you mentioned if it's a more official source but I can't find any registrations data there. Let me know if you can find it. If it's not on the website, we will stick with bilsweden.se. Thanks
    @Atlantis,
    124 is YTD at the end of Feb: 109+15=124
    Q1 is 15+109+355= 479
  3. aubreymcfato
    aubreymcfato Supporting Member
    Italy
    Other countries will be a surprise this Q ;-)
  4. AndyH
    AndyH Supporting Member
    Sweden
    Yes, use bilswedens nyregistreringar. The numbers are correct it's just that the last few days might be deferred to next quarter. Note: They usually publish numbers in their news feed a couple of days before they're available at the statistics page.
    Other numbers seems difficult to obtain.
  5. Atlantis
    Atlantis Member
    Portugal
    You are right. Sorry,my bad:)
  6. Lauz
    Lauz Member
    Denmark
  7. mrdoubleb
    mrdoubleb Supporting Member
    Budapest, Hungary
    UK March SMMT data shows 711 other imports. Based on last year's Tesla portion of March "other imports" the formula estimates 450 Teslas for the month
  8. mrdoubleb
    Budapest, Hungary
    So that was just for the "evidence" for the data. I do want to caution though as this method - while there is clearly no better way to estimate - has consequently overestimated Tesla's share the past few months we could compare it to actual data. And that before the drop in MS/MX sales we've seen globally. So I believe that 450 is a lot lower this time around. Sadly it will take months to get the actual data.
  9. mrdoubleb
    Budapest, Hungary
    @Troy I've deleted (un-validated) my UK March entry as it screwed up the Model 3 numbers - the formula thought 422 were Model 3s. So I have re-entered the data with an estimated 55-45% S/X split based on your January calculations.
  10. Troy
    Troy Active Member
    @hobbes, shall we add Portugal and Denmark to the main list? Portugal finished Q1 with 479 and Denmark with 413 registrations. Portugal is not on the list because there was no data in 2018. Denmark is not on the list because last year's registrations were low.
  11. hobbes
    hobbes Active Member
    Germany
    Yeah fine, go ahead!
  12. Atlantis
    Atlantis Member
    Portugal
    • Informative x 2
  13. mrdoubleb
    Budapest, Hungary
    #213 mrdoubleb, Apr 8, 2019
    @Troy Thanks for going back and adding in the detailed data for the countries where we only had totals last week - was just about to do that wen I saw your entries! I've validated most of your numbers, but I had 2 issues:
    • For Denmark you've entered 306 Model 3s for March, but I think the actual number should be 292. If you make a new entry I am happy to validate it.
    • For France the dropdowns are missing for the validation fields so I could not do that. The data checks out though.
  14. mrdoubleb
    Budapest, Hungary
    @Troy I am still unable to validate your entries as the dropdowns on the green fields are missing for me. Tried in Chrome and Edge as well.
  15. Troy
    Troy Active Member
    @mrdoubleb, thanks. I thought I had fixed it but it turns out some recently added rows were locked. It should be OK now.
  16. mrdoubleb
    Budapest, Hungary
    Thx. Done!
  17. Troy
    Troy Active Member
    #217 Troy, Apr 12, 2019
    The official UK registration numbers for Q4 2018 are out. The total was 675 units. Our estimate was 712 units. We were off by (712-675)/675= 5.5%
    Compared to Q4 2017, Q4 2018 dropped by 45%. That's definitely a big drop. Not sure why it happened. Both the S and X numbers dropped equally.
    Source file
    UK only publishes quarterly numbers instead of monthly. We use SMMT data (Society of Motor Manufacturers and Traders) to split the quarterly numbers into monthly. This is explained here.
    UK numbers also include registrations by trim level:
    Source file
  18. AndyH
    Sweden
    #218 AndyH, May 1, 2019
    Danish numbers are out for April(Excel file near the top).
    M3 168
    S 2
    X 0
    Sweden will be out tomorrow. May 1st is a holiday here.
    Edit: This will bring the total in 1st post table for Denmark to 569 but the link above qoute 583 as Denmark's total for this year.
  19. Troy
    Troy Active Member
    #219 Troy, May 2, 2019
    @aubreymcfato, check out the list here for data sources we use. We try to pick the best source for each country. Official or institutional sources are preferred if there is one.
    @AndyH, you found the correct source for Denmark. You can use the form here to add the data. Any forum member can. We encourage entries by forum members. Somebody else will check the data to avoid errors. Currently, 3 or 4 people check all entries and it helps if others submit them. Btw, right click to the Excel link, copy it and use that as data source. Edit: I just noticed that Model X seems to be missing on the spreadsheet. Maybe it's better to wait for them to update this page.
  20. Jussi83
    Jussi83 Member
    Finland
Thread Status:
