Does Tesla inform of available update via mobile app when the car is not on WIFI.
Context: I have turned off wifi, to let the car sleep more and save energy.
wifi availability doesn't impact sleep at all nor does it impact update availabilityDoes Tesla inform of available update via mobile app when the car is not on WIFI.
That's what Tesla says, but I don't think our cars have downloaded any updates via LTE in the last 2-3 years. On the other hand, our cars have access to WiFi when parked at home, so it's possible some updates I received via WiFi would have downloaded via LTE if no WiFi was available. Map updates definitely require WiFi.Most updates yes, but Tesla will still push some over cellular if they consider them high priority.
I'm curious why the OP thinks that turning off wifi saves battery or lets the car sleep more.
Bingo!, I have a had a lot of issues with Phantom drain, so I was eliminating all things like 3rd party monitoring (teslafi , etc.. etc.) among other things and one of the comments were related to unstable wifi signal, so I had stopped this; I did not have a need to restart this process again and became curious and wanted to know about the notification process.The theory is that I've heard is a weak wifi signal is worse than no signal since it's constantly seeking. Haven't looked into this though.
I can absolutely confirm that my car downloaded an update over LTE in February after being off of WiFi for over a month.That's what Tesla says, but I don't think our cars have downloaded any updates via LTE in the last 2-3 years. On the other hand, our cars have access to WiFi when parked at home, so it's possible some updates I received via WiFi would have downloaded via LTE if no WiFi was available. Map updates definitely require WiFi.
that is a true statement - just not in the context of downloading updatesI do believe the phone and the car talk to each other over bluetooth.
I disabled wifi when I learned about the messed up UI with "holiday update". I don't remember how long exactly, but within a month of release it downloaded itself over LTE. After a week I caved and pressed the install button. I wish I hadn't like some of the guys here that are still holding out.That's what Tesla says, but I don't think our cars have downloaded any updates via LTE in the last 2-3 years. On the other hand, our cars have access to WiFi when parked at home, so it's possible some updates I received via WiFi would have downloaded via LTE if no WiFi was available. Map updates definitely require WiFi.
I'm in and out of my garage often. With wifi on the car is awake much more frequently. Presumably with wifi on at all times, it is phoning home to mothership much more frequently. After I disconnected from wifi (must forget the wifi profile completely), one time I didn't drive the car for a whole week and the battery only dropped 2%. With wifi connected at all times it can lose that in a day.I'm curious why the OP thinks that turning off wifi saves battery or lets the car sleep more.
I definitely believe that to be true. My wifi router is at the other end of my house and signal was extremely weak in the garage. Since I added a mesh wifi node in my garage (and before I permanently disconnected my car from wifi), the car woke much less frequently.The theory is that I've heard is a weak wifi signal is worse than no signal since it's constantly seeking. Haven't looked into this though.
I have a mesh node in my garage so the car has high quality signal. It routinely sleeps for 12+ hours at a stretch (as shown on TeslaFi), so I do not believe WiFi availability, in itself, causes more frequent wakes and thus battery drain. Be aware that any use of the Tesla app will wake the car up if it is sleeping! TeslaFi knows when the car is sleeping and does not wake it up unless you tell it to.I disabled wifi when I learned about the messed up UI with "holiday update". I don't remember how long exactly, but within a month of release it downloaded itself over LTE. After a week I caved and pressed the install button. I wish I hadn't like some of the guys here that are still holding out.
what made the biggest difference for me was setting the car to not lock when in the garage. That stops it waking up because its not locked when anyone goes into the garage. I also keep Senry disabled at home, standby summon off etc.I'm in and out of my garage often. With wifi on the car is awake much more frequently. Presumably with wifi on at all times, it is phoning home to mothership much more frequently. After I disconnected from wifi (must forget the wifi profile completely), one time I didn't drive the car for a whole week and the battery only dropped 2%. With wifi connected at all times it can lose that in a day.
