I agree. The problem is that you need the semi truck properly labeled and located by both the LIDAR and the camera streams before giving instructions to avoid it.You definitely need cameras. I'm not sure how much labeling is done on LIDAR data. Obviously you can feed both LIDAR data and camera data into the same perception neural net. I'm not an expert but certain types of decision making are very simple (i.e. don't run into the side of the semi truck trailer that the vision neural net didn't see!).
I don't disagree that LIDARs can work just fine with cameras, but that will require significantly more resources. If the system can be simplified, we should always go for it.I'll also point out that Tesla has a neural net that creates a Vidar data stream (exactly the same type of depth data that LIDAR does, just with lower accuracy) so they'll have to figure out how to merge those two streams for decision making too.
People often say LIDAR causes all sorts of problems but if you look at the actual collisions that AVs with LIDAR have they always seem to have nothing to do with LIDAR.
Then I guess that bumper cars is your vision for the future. Well, why not?Sure, if it was able to bounce off of whatever it crashed into without damage and carry on.
Not sure why it has to be labeled, just don't run into large objects, there's no need to know what it is. Someone is probably going to bring up the plastic bag example but I'm pretty sure you don't need to train neural net to tell the difference between a plastic bag and a giant object.I agree. The problem is that you need the semi truck properly labeled and located by both the LIDAR and the camera streams before giving instructions to avoid it.
Of course, that's why a lot of companies are getting rid of RADAR for their driver assist systems. Computer vision has gotten good enough that cheap RADAR doesn't add enough to justify the cost. Unfortunately depth information from computer vision systems has not reached parity with humans (note how often FSD Beta users hit curbs). Right now the only technology that can match human performance is LIDAR though that certainly may change in the future.I don't disagree that LIDARs can work just fine with cameras, but that will require significantly more resources. If the system can be simplified, we should always go for it.
That depends entirely on the use case. Camera data is easy to process if all you need to do is adjust the contrast. Far harder if you are trying to figure out if the object "over there" is a car or not.I guess I'll take #3. LIDAR data is very simple and far easier to process than camera data (Samsung makes a robot vacuum that uses LIDAR!). It does not require neural networks at all.
Obviously we're talking about computer vision in this forum, not image processing.That depends entirely on the use case. Camera data is easy to process if all you need to do is adjust the contrast. Far harder if you are trying to figure out if the object "over there" is a car or not.
Yes, it produces less data (that was part of misinformation you were asking about). However, the depth data it produces cannot reliably be produced by computer vision yet.In fact LIDAR data is far less voluminous, in that the number of data points is a couple orders of magnitude less that camera data. Also, since LIDAR cannot identify an object (its far too low resolution), essentially it is auxiliary data. It tells you "something in this direction is this far away and is moving with this velocity" but can't tell you much more without the assistance of an NN to integrate and recognize boundaries (which can only really be done in conjunction with camera data).
Probably about as well as Smart Summon.I suggest you bolt your robot vacuum to the front of your car and see how well it navigates city streets.
Certainly, you have no clue. Ford has Co-Pilot360 for a long time that allowed drivers to go hands free for short time even on country roads, and it had no camera monitoring of the driver.
This video may help you to learn more about the real functionality of Fords autopilot.
Could you please name a couple "basic safety issues"? Thank you.
Thank you for interesting information. It's no surprise, however, the FSD Beta has issues. My question was regarding the Autopilot safety issues rather than the FSD Beta.I just got the most modern, most updated FSD beta 10.2:
Are you suggesting that AP is more mature, safer, has less safety issues or better than FSD beta?Thank you for interesting information. It's no surprise, however, the FSD Beta has issues. My question was regarding the Autopilot safety issues rather than the FSD Beta.
Yes.Are you suggesting that AP is more mature, safer, has less safety issues or better than FSD beta?
